Community
cancel
Showing results for
Search instead for
Did you mean:
veek04
DDR transactions on FPGA
As I want to write some chunks of data to FPGA memory (DDR) and read the data from DDR at a time , is there any API calls to do it other than CL_MEM_ALLOC_HOST_PTR / CL_MEM_USE_HOST_PTR. Is there any way to achieve it.
Tags (1)
BoonT_Intel
Can you help to confirm the DDR that you mentioned here is External Memory device like DDR3/4?
I am asking because the term that you said like CL_MEM_ALLOC_HOST_PTR / CL_MEM_USE_HOST_PTR is not a common term in External Memory world. Can you help to elaborate this term further?
veek04
I have external Memory Device like DDR4.
Is there any way to do DDR based transaction in OpenCL.
