Community
cancel
Showing results for
Search instead for
Did you mean:
Debugging with OpenCL Code Builder
Hello!
I tried to debug my first OpenCL application with the Visual Studio Plugin "OpencC Code Builder" (Intel SDK for OpenCL Application 2017 Beta, 7.0.0.2567). The Data View does not work properly because the raw data associated with the object buffer does not appear inside the view. The history combo box is also empty.
Is there a solution to the problem with Data View?
Thanks!
