Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Decoding-opencl-encoding pipeline
I am working on Decode-OPENCL-Encode pipeline on intel processor. There is a sample code provide by intel for media interop which is attached.
I am integrating the encoder into same.
If we look at the DecodeOneFrame() function below:
mfxStatus CDecodingPipeline::DecodeOneFrame(int Width, int Height, IDirect3DSurface9 *pDstSurface, IDirect3DDevice9* pd3dDevice)
    mfxU16 nOCLSurfIndex=0;
    mfxStatus stsOut = MFX_ERR_NONE;
    if(m_Tasks[m_TaskIndex].m_DecodeSync || m_Tasks[m_TaskIndex].m_OCLSync || m_Tasks[m_TaskIndex].m_EncodeSync)
    {// wait task is finished and copy result texture to back buffer
        mfxStatus   sts = MFX_ERR_NONE;
        mfxFrameSurface1_OCL*   pOutSurface = NULL; // output surface.
        //wait the previous submitted tasks
        if(m_Tasks[m_TaskIndex].m_DecodeSync)
            sts = m_mfxSession.SyncOperation(m_Tasks[m_TaskIndex].m_DecodeSync, MSDK_DEC_WAIT_INTERVAL);
            MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, sts);
            pOutSurface = m_Tasks[m_TaskIndex].m_pDecodeOutSurface;
        if(m_Tasks[m_TaskIndex].m_OCLSync)
            sts = m_mfxSession.SyncOperation(m_Tasks[m_TaskIndex].m_OCLSync, MSDK_VPP_WAIT_INTERVAL);
            pOutSurface = m_Tasks[m_TaskIndex].m_pOCLOutSurface;
#ifdef ENCODER
        if(m_Tasks[m_TaskIndex].m_EncodeSync)
            sts = m_mfxSession.SyncOperation(m_Tasks[m_TaskIndex].m_EncodeSync, MSDK_ENC_WAIT_INTERVAL);
                  //pOutSurface = m_Tasks[m_TaskIndex].m_pEncodeOutSurface;
#endif
        if(pOutSurface)
        {/* copy YUV texture to screen */
            HRESULT hr;
            IDirect3DSurface9* pSrcSurface = (IDirect3DSurface9*)(pOutSurface->Data.MemId);
            assert(pDstSurface && pSrcSurface);
            if(pSrcSurface && pDstSurface)
                RECT    r;
                r.left = 0;
                r.top = 0;
                r.right = min(Width,m_mfxDecodeVideoParams.vpp.In.Width);
                r.bottom = min(Height,m_mfxDecodeVideoParams.vpp.In.Height);
                r.right -= r.right&1;
                r.bottom -= r.bottom&1;
                V(pd3dDevice->StretchRect(pSrcSurface, &r, pDstSurface, &r,D3DTEXF_POINT));
#ifdef UNLOCK
        if(m_Tasks[m_TaskIndex].m_pDecodeOutSurface && m_Tasks[m_TaskIndex].m_pDecodeOutSurface->Data.Locked)
          _InterlockedDecrement16((short*)&m_Tasks[m_TaskIndex].m_pDecodeOutSurface->Data.Locked);
        if(m_Tasks[m_TaskIndex].m_pOCLOutSurface && m_Tasks[m_TaskIndex].m_pOCLOutSurface->Data.Locked)
            _InterlockedDecrement16((short*)&m_Tasks[m_TaskIndex].m_pOCLOutSurface->Data.Locked);
#ifdef ENCODER
        if(m_Tasks[m_TaskIndex].m_pEncodeOutSurface && m_Tasks[m_TaskIndex].m_pEncodeOutSurface->Data.Locked)
            _InterlockedDecrement16((short*)&m_Tasks[m_TaskIndex].m_pEncodeOutSurface->Data.Locked);
#endif
#endif
#if 1
    // clear sync task for further using
    m_Tasks[m_TaskIndex].m_OCLSync = 0;
    m_Tasks[m_TaskIndex].m_pOCLOutSurface = 0;
    m_Tasks[m_TaskIndex].m_DecodeSync = 0;
    m_Tasks[m_TaskIndex].m_pDecodeOutSurface = 0;
#ifdef ENCODER
    m_Tasks[m_TaskIndex].m_EncodeSync = 0;
    m_Tasks[m_TaskIndex].m_pEncodeOutSurface = 0;
#endif
#endif
    if(m_DECODEFlag)
    {// feed decoder
        mfxSyncPoint        DecodeSyncPoint = 0;
        static mfxU16      nDecoderSurfIndex = 0; // index of free surface
        m_pmfxDecodeSurfaceLast = NULL; // reset curretn decoder surface to get new one from Decoder
        while(MFX_ERR_NONE <= sts || MFX_ERR_MORE_DATA == sts || MFX_ERR_MORE_SURFACE == sts || MFX_WRN_DEVICE_BUSY == sts)
        {// loop until decoder report that it get request for new frame
            if (MFX_WRN_DEVICE_BUSY == sts)
                Sleep(1); // just wait and then repeat the same call to DecodeFrameAsync
            else if (MFX_ERR_MORE_DATA == sts)
            { // read more data to input bit stream
                sts = m_FileReader.ReadNextFrame(&m_mfxBS);
                MSDK_BREAK_ON_ERROR(sts);
            else if (MFX_ERR_MORE_SURFACE == sts || MFX_ERR_NONE == sts)
            {// find new working-output surface in m_pmfxDecodeSurfaces
                //nDecoderSurfIndex = 0;
                nDecoderSurfIndex = GetFreeSurfaceIndex(m_pmfxDecodeSurfaces, m_mfxDecoderResponse.NumFrameActual,nDecoderSurfIndex);
                if (MSDK_INVALID_SURF_IDX == nDecoderSurfIndex)
                    return MFX_ERR_MEMORY_ALLOC;
            // send request to decoder
            sts = m_pmfxDEC->DecodeFrameAsync(
                &m_mfxBS,
                (mfxFrameSurface1*)&(m_pmfxDecodeSurfaces[nDecoderSurfIndex]),
                (mfxFrameSurface1**)&m_pmfxDecodeSurfaceLast,
                &DecodeSyncPoint);
            // ignore warnings if output is available,
            // if no output and no action required just repeat the same call
            if (MFX_ERR_NONE < sts && DecodeSyncPoint)
                sts = MFX_ERR_NONE;
            if (MFX_ERR_NONE == sts)
            {// decoder return sync point then fill the curretn task nad switch to OCL Plugin feeding
                m_Tasks[m_TaskIndex].m_DecodeSync = DecodeSyncPoint;
                m_Tasks[m_TaskIndex].m_pDecodeOutSurface = m_pmfxDecodeSurfaceLast;
                // look for output process
#ifdef UNLOCK
                if(m_Tasks[m_TaskIndex].m_pDecodeOutSurface)
                    _InterlockedIncrement16((short*)&m_Tasks[m_TaskIndex].m_pDecodeOutSurface->Data.Locked);
#endif
                break;
        if(MFX_ERR_NONE != sts)
            printf("ERROR: Decoder returns error %d!\n",sts);
            stsOut = sts;
        //decoder sync point
    }//if(m_DECODEFlag)
    if(m_pOCLPlugin && m_pOCLPlugin->m_OCLFlag)
    {// OPENCL part
        mfxSyncPoint        OCLSyncPoint = 0;
        // get index for output surface for OCL plugin
        nOCLSurfIndex = GetFreeSurfaceIndex(m_pmfxOCLSurfaces, m_mfxOCLResponse.NumFrameActual);
        MSDK_CHECK_ERROR(nOCLSurfIndex, MSDK_INVALID_SURF_IDX, MFX_ERR_MEMORY_ALLOC);
        //mfxHDL pOutSurf = &m_pmfxOCLSurfaces[nOCLSurfIndex];
        //mfxHDL pOutSurf = &m_pmfxEncSurfaces[nEncSurfIdx];
        //m_pmfxOCLSurfaces[nOCLSurfIndex] = m_pmfxEncSurfaces[nEncSurfIdx];
        mfxHDL inp = m_pmfxDecodeSurfaceLast;
        // OCL filter
        for(;;)
          sts = MFXVideoUSER_ProcessFrameAsync(m_mfxSession, &inp, 1, &pOutSurf, 1, &OCLSyncPoint);
            else
                break;
        if (MFX_ERR_NONE < sts && OCLSyncPoint)
            sts = MFX_ERR_NONE;
        if(MFX_ERR_NONE!=sts)
            printf("ERROR: OpenCL filter return error %d!\n",sts);
            return sts;
            m_Tasks[m_TaskIndex].m_OCLSync = OCLSyncPoint;
            m_Tasks[m_TaskIndex].m_pOCLOutSurface = &m_pmfxOCLSurfaces[nOCLSurfIndex];
            //m_Tasks[m_TaskIndex].m_pOCLOutSurface = &m_pmfxEncSurfaces[nEncSurfIdx];
#ifdef UNLOCK
            _InterlockedIncrement16((short*)&m_Tasks[m_TaskIndex].m_pOCLOutSurface->Data.Locked);
#endif
#ifdef ENCODER
    if(m_ENCODEFlag)
    {// feed encoder
        static mfxU16      nEncSurfIdx = 0; // index of free surface
        mfxSyncPoint EncSyncP;
        //mfxFrameSurface1* pSurf = NULL; // dispatching pointer
        // find free surface for encoder input
        nEncSurfIdx = GetFreeSurface(m_pmfxEncSurfaces, m_mfxEncResponse.NumFrameActual);
        MSDK_CHECK_ERROR(nEncSurfIdx, MSDK_INVALID_SURF_IDX, MFX_ERR_MEMORY_ALLOC);
        // point pSurf to encoder surface
        //m_pmfxEncSurfaces[nEncSurfIdx] = m_pmfxOCLSurfaces[nOCLSurfIndex];
        for (;;)
            // at this point surface for encoder contains either a frame from file or a frame processed by vpp
            sts = m_pmfxENC->EncodeFrameAsync(NULL, &m_pmfxEncSurfaces[nEncSurfIdx], &m_mfxEncBS, &EncSyncP);
            if (MFX_ERR_NONE < sts && !EncSyncP) // repeat the call if warning and no output
                    MSDK_SLEEP(1); // wait if device is busy
            else if (MFX_ERR_NONE < sts && EncSyncP)
                sts = MFX_ERR_NONE; // ignore warnings if output is available
                break;
            else if (MFX_ERR_NOT_ENOUGH_BUFFER == sts)
                sts = AllocateSufficientBuffer(&m_mfxEncBS);
                printf("\n BUFFER allocated");
            else
                // get next surface and new task for 2nd bitstream in ViewOutput mode
                MSDK_IGNORE_MFX_STS(sts, MFX_ERR_MORE_BITSTREAM);
                break;
      if (MFX_ERR_MORE_DATA == sts) {
        sts = MFX_ERR_NONE;
            m_Tasks[m_TaskIndex].m_EncodeSync = EncSyncP;
#ifdef UNLOCK
      {// encoder return sync point then fill the curretn task nad switch to encoder feeding
          m_Tasks[m_TaskIndex].m_pEncodeOutSurface = &m_pmfxEncSurfaces[nEncSurfIdx];
          _InterlockedIncrement16((short*)&m_Tasks[m_TaskIndex].m_pEncodeOutSurface->Data.Locked);
#endif
#endif
    // increase task index to point to next task.
    m_TaskIndex = (m_TaskIndex+1)%SYNC_BUF_SIZE;
    return stsOut;
}//CDecodingPipeline::DecodeOneFrame
If I use this code the encoder output is corrupted.When I decode the encoder output It seems frames are not displayed in proper order.
I think I am not giving the right surface to encoder as the encoder surface index is independently calculated.
But when I give the OCL output surface to encoder then my OCL also stops working.
Can anyone guide me here?
Highlighted
Hi Manish,
We have an OpenCL forum, you should be able to get the help you need there. I am moving your post to that forum.
