I installed the intel PAC recently and I went through the installation guides to install the opae and drivers and I finished the installations. Then, I used "aocl install" to install the opencl driver.
Now when I try to Load the BSP with the hello_world.aocx to initialize the PAC with the hello_world example I get the following error:
aocl program: Running program from /opt/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
libopae-c bitstream.c:387:validate_bitstream_metadata() **ERROR** : Interface ID check failed
Error writing bitstream to FPGA: invalid parameter
Error programming device
aocl program: Program failed.
And I cannot use the PAC, also, this is the output of the fpgainfo fme:
Board Management Controller, microcontroller FW version 26889
Last Power Down Cause: POK_CORE
Last Reset Cause: External reset
Power-on-reset
//****** FME ******//
Object Id : 0xF000000
PCIe s:b:d:f : 0000:01:00:0
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Bitstream Id : 0x123000200000185
Bitstream Version : 1.2.3
Pr Interface Id : 69528db6-eb31-577a-8c36-68f9faa081f6
Boot Page : user
I was wondering if anybody faced the same issue?
Best,
Mostafa
Hi Mostafa,
Did you create hello_world.aocx using Acceleration Stack?
You can find guides for PAC card here.
Sergey
