OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Eclipse Code Builder - kernel arguments and configuration locked
MathieuT
I 'm currently trying to deploy Intel OpenCL on the GPU of my Intel(R) Xeon(R) CPU E3-1505M v5 @ 2.80GHz on Centos 7.1. My configuration is :
- intel_sdk_for_opencl_2016_6.3.0.1904_x64.tgz
- driver r3.1.58620
- eclipse Oxygen, jre-8u111-linux-x64, mono-4.0.1-4.x86_64
I'm following the Code Builder tutorial. Every thing works fine until this step : https://software.intel.com/en-us/node/671857
When I try to launch the kernel, I have an error message telling me that the buffers are not assigned:
execution analysis error: No variable assigned to kernel argument #0 (ptrInput)
So I go to the OpenCL Kernel Analysis Input view and the configuration as well as the assigned variables are all in grey. I cannot click on the configuration and the kernel variables fields are empty.
Can you please help me ?
Mathieu
Here are the buffers I have declared :
<!--  Kernel Builder Variables Database  -->
<KernelBuilderBuffers>
    <BufferDetails>
        <Name>ptrInput</Name>
        <DataType>uchar</DataType>
        <MemoryFlags>CL_MEM_READ_WRITE</MemoryFlags>
        <AccessQualifier>READ_ONLY</AccessQualifier>
        <I_O_Mode>0</I_O_Mode>
        <Source>/home/user/STI/THOREL/workspace_eclipse/Code Builder Sessions/session_0/bin_ptrInput.bin</Source>
        <ReadOutput>true</ReadOutput>
        <BufferSize>262144</BufferSize>
        <InitByRandom>false</InitByRandom>
        <InitByZero>true</InitByZero>
        <UseAsSVM>false</UseAsSVM>
    </BufferDetails>
    <BufferDetails>
        <Name>ptrOutput</Name>
        <I_O_Mode>1</I_O_Mode>
        <Source></Source>
        <InitByZero>false</InitByZero>
    </BufferDetails>
</KernelBuilderBuffers>
<KernelBuilderImages/>
<KernelBuilderSamplers/>
The kernel is :
#define FILTER_WIDTH ( 11 )
#define FILTER_SIZE  ( FILTER_WIDTH * FILTER_WIDTH )
#define FILTER_INF   ( 5 ) // Need to be calculated -> floor( FILTER_WIDTH / 2 )
__kernel void convolve_no_local( const __global unsigned char * restrict ptrInput,
                                       __global unsigned char * restrict ptrOutput,
                                 const          int                      iWidth,
                                 const          int                      iHeight )
    // Must be normalized
    const int arrFilter[ FILTER_SIZE ] = { -2, -2, -2, -2, -2, -2, -2, -2, -2, -2,  0,
                                           -2, -2, -2, -2, -2, -2, -2, -2, -2,  0,  2,
                                           -2, -2, -2, -2, -2, -2, -2, -2,  0,  2,  2,
                                           -2, -2, -2, -2, -2, -2, -2,  0,  2,  2,  2,
                                           -2, -2, -2, -2, -2, -2,  0,  2,  2,  2,  2,
                                           -2, -2, -2, -2, -2,  0,  2,  2,  2,  2,  2,
                                           -2, -2, -2, -2,  0,  2,  2,  2,  2,  2,  2,
                                           -2, -2, -2,  0,  2,  2,  2,  2,  2,  2,  2,
                                           -2, -2,  0,  2,  2,  2,  2,  2,  2,  2,  2,
                                           -2,  0,  2,  2,  2,  2,  2,  2,  2,  2,  2,
                                            0,  2,  2,  2,  2,  2,  2,  2,  2,  2,  2 };
    const int iWorkGlobalX = get_global_id( 0 );
    const int iWorkGlobalY = get_global_id( 1 );
    if( iWorkGlobalX >= FILTER_INF && iWorkGlobalX < iWidth  - FILTER_INF &&
        iWorkGlobalY >= FILTER_INF && iWorkGlobalY < iHeight - FILTER_INF )
        const int iInputX = ( iWorkGlobalX - FILTER_INF );
        const int iInputY = ( iWorkGlobalY - FILTER_INF );
        int iInput;
        int iValue = 0;
#ifdef __UNROLL_3x3__
        iInput = iInputX + iInputY * iWidth;
        iValue = iValue + ( arrFilter[ 0 ] * convert_int( ptrInput[ iInput     ] ));
        iValue = iValue + ( arrFilter[ 1 ] * convert_int( ptrInput[ iInput + 1 ] ));
        iValue = iValue + ( arrFilter[ 2 ] * convert_int( ptrInput[ iInput + 2 ] ));
        iInput = iInput + iWidth;
        iValue = iValue + ( arrFilter[ 3 ] * convert_int( ptrInput[ iInput     ] ));
        iValue = iValue + ( arrFilter[ 4 ] * convert_int( ptrInput[ iInput + 1 ] ));
        iValue = iValue + ( arrFilter[ 5 ] * convert_int( ptrInput[ iInput + 2 ] ));
        iValue = iValue + ( arrFilter[ 6 ] * convert_int( ptrInput[ iInput     ] ));
        iValue = iValue + ( arrFilter[ 7 ] * convert_int( ptrInput[ iInput + 1 ] ));
        iValue = iValue + ( arrFilter[ 8 ] * convert_int( ptrInput[ iInput + 2 ] ));
#else
        int iRow;
        int iCol;
        int iFilter = 0;
        for( iRow = 0 ; iRow < FILTER_WIDTH ; iRow++ )
            iInput = iInputX + ( iInputY + iRow ) * iWidth;
            for( iCol = 0 ; iCol < FILTER_WIDTH ; iCol++ )
                iValue = iValue + ( arrFilter[ iFilter ] * convert_int( ptrInput[ iInput ] ));
                iInput++;
                iFilter++;
#endif
        ptrOutput[ iWorkGlobalX + iWorkGlobalY * iWidth ] = convert_uchar_sat( iValue );
Here are the view screeshots :
Jeffrey_M_Intel1
The only Eclipse versions supported right now are Mars and Luna.  (See https://software.intel.com/en-us/intel-opencl). ; According to Eclipse, Oxygen is not due to be released until June 2017.   Is there any chance you could try one of these earlier supported versions of Eclipse?
Jeffrey_M_Intel1
MathieuT
As you mentioned I installed Eclipse Mars.2 and it works even if sometimes the OpenCL Kernel Analysis Input view crash. Thank you Jeffrey.
I can now select the buffers and launch the kernel. However, the firefox (version 51 and 38) html report page is empty. An error message is displayed: "Error: can not find main menu data". So I manually opened the main.js file where it comes from ans it appears that the file '/data/mainMenu.ajax' is missing.
I think it should be generated during the execution. You will find attach to this message the output of the execution : 20161220111137.zip
Can you please help me with this
Mathieu
Jeffrey_M_Intel1
I've been able to reproduce similar behavior.  A bug has been filed.  Thanks for your helpful input on this.
