Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Error when running aocl install
Below is the terminal command and all output for running aocl install on s10_ref supplied with the FPGA SDK for OpenCL for Ubuntu. Some of the install works, then it crashes for the reasons given below.
To try and fix the error, I reinstalled linux-headers-generic but it did not fix the error. Thank you for any help with this issue.
sudo env "PATH=$PATH" aocl install .
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] y
aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege
Install the FCD file to /opt/Intel/OpenCL/Boards
aocl install: Adding the board package /home/niko/intelFPGA_pro/19.4/hld/board/s10_ref to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /home/niko/intelFPGA_pro/19.4/hld/board/s10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/5.3.0-45-generic/build
Using kernel source files from  /lib/modules/5.3.0-45-generic/build
Building driver for BSP with name s10_ref
make: Entering directory '/usr/src/linux-headers-5.3.0-45-generic'
  CC   /tmp/opencl_driver_s5Q4ey/aclpci_queue.o
  CC   /tmp/opencl_driver_s5Q4ey/aclpci.o
/tmp/opencl_driver_s5Q4ey/aclpci.c: In function ‘load_signal_info’:
/tmp/opencl_driver_s5Q4ey/aclpci.c:371:26: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
   struct siginfo *info = &aclpci->signal_info;
/tmp/opencl_driver_s5Q4ey/aclpci.c:382:8: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
   info = &aclpci->signal_info_dma;
cc1: some warnings being treated as errors
scripts/Makefile.build:288: recipe for target '/tmp/opencl_driver_s5Q4ey/aclpci.o' failed
make[1]: *** [/tmp/opencl_driver_s5Q4ey/aclpci.o] Error 1
Makefile:1655: recipe for target '_module_/tmp/opencl_driver_s5Q4ey' failed
make: *** [_module_/tmp/opencl_driver_s5Q4ey] Error 2
make: Leaving directory '/usr/src/linux-headers-5.3.0-45-generic'
aocl install: failed.
aocl install: Removing FCD
aocl install: Removing the board package /home/niko/intelFPGA_pro/19.4/hld/board/s10_ref from the list of installed packages
Highlighted
Hi Nikolas,
What is your Ubuntu version and Linux kernel version?
Sergey
Highlighted
Hi Sergey,
Ubuntu version is 18.04.1 and my kernel version is 5.3.0-45-generic.
Nick
Highlighted
Hi Nikolas,
Try to downgrade your kernel to 4.15 and install sources and headers for 4.15.
This should help.
Sergey
Highlighted
Hi Nikolas,
You will need to make some changes to the drivers to get it to install in Ubuntu 18.04, but its doable.  I have it running on my machine with kernel 5.3.0. See
QG
