OpenCL* for CPU
Existing code using OpenCL C++ Wrapper would not compile properly
WeiChong_T_Intel
I have an existing C++ application that uses OpenCL C++ Wrapper API, which compiled on an earlier Intel OpenCL SDK (I forgot the version), but after I upgrade my laptop to Windows 8.1, Visual Studio 2013 Ultmate, with the below spec:
Intel® Driver Update Utility
Product Detected  Intel® HD Graphics 4400
Current Driver Installed  10.18.10.3907
Your driver is current.
Intel® SDK for OpenCL Applications 2014 version 4.6.0.92
My code would no longer compile.  The errors is:
Warning    1    warning C4996: 'clCreateSampler': was declared deprecated    C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    4312    1    OpenCLProject1
Warning    2    warning C4996: 'clCreateCommandQueue': was declared deprecated    C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    5118    1    OpenCLProject1
Warning    3    warning C4996: 'clCreateCommandQueue': was declared deprecated    C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    5148    1    OpenCLProject1
Warning    4    warning C4996: 'clCreateCommandQueue': was declared deprecated    C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    5166    1    OpenCLProject1
Warning    5    warning C4996: 'clEnqueueTask': was declared deprecated    C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    5947    1    OpenCLProject1
    6    IntelliSense: member "cl::detail::Wrapper<cl_device_id>::object_" (declared at line 1787 of "C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL/cl.hpp") is inaccessible    c:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    1819    23    OpenCLProject1
    7    IntelliSense: member "cl::detail::Wrapper<cl_device_id>::object_" (declared at line 1787 of "C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL/cl.hpp") is inaccessible    c:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    1827    23    OpenCLProject1
    8    IntelliSense: member "cl::detail::Wrapper<cl_device_id>::referenceCountable_" (declared at line 1788 of "C:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL/cl.hpp") is inaccessible    c:\Program Files (x86)\Intel\OpenCL SDK\4.6\include\CL\cl.hpp    1828    35    OpenCLProject1
Is this because of version incompatiblity? If so, is there a way I can find out the correct version and specifically build my application against that version?
Robert_I_Intel
Wei Chong,
Were you able to resolve the issue? Is this the same project that you sent me? I haven't encountered this particular problem. Could you send me the project with this issue directly to my email.
