I have downloaded few application such as matrix multiplication form the code samples given in this site. I am trying to trace the function calls of those applications using perf. perf is listing the function names but they are in hex-code. In order to get the name of the function I need to get the debugger version it seems. But I couldn't find it in the site.
In the Makefile, a -g option was available but it didn't work.
Could anyone please help?
Thanks & regards,
Sudipta Paul
which sample application do you use exactly? Please provide the link where you downloaded it.
You'd need the source code and (re)compile with -g to get debug information.
Please elaborate.
Georg Zitzlsberger
here is the link:
https://software.intel.com/en-us/intel-opencl-support/code-samples
I am using General matrix multiplication
(it is listed under "OpenCL 1.2 samples for Linux:")
I tried debugging the code with -g option but it didn't work. The result was "make: invalid option -- 'g'" then it listed out all the options. There was an option "--debug". That doesn't seem to work either.
Could you please suggest something.
Thanks and regards,
Sudipta
For more complete information about compiler optimizations, see our Optimization Notice.
Thank you for the link. Since this is related to OpenCL* I'll reassign it to the proper forum.
Georg Zitzlsberger
