Dear ALL:
My computer's CPU is intel i7-8700K (12 cores), and also has a Nvidia GPU: GTX 1080 card, and the OS is Ubuntu1604 LTS。
I want to use gstreamer gst to test hardware accelerated decoding using intel integrated GPU and nvidia GTX 1080 simultaneously.
First, I can use nivida deepstream plugin for gst to decode vedio files using gtx1080 successfully.
The command as this:
#gst-launch-1.0 filesrc location=./Clip_1080_5sec_10mbps_h264.mp4 ! qtdemux ! h264parse ! nvdec_h264 ! fakesink
Second , I installed intel media sdk and gstreamer media sdk and vaapi driver from sources.
gst can find the mfx plugins:
#gst-inspect-1.0 | grep mfx
mfx: mfxh264dec: MFX H264 decoder
mfx: mfxhevcdec: MFX HEVC decoder
mfx: mfxmpeg2dec: MFX MPEG2 decoder
mfx: mfxvc1dec: MFX VC1 decoder
mfx: mfxvp8dec: MFX VP8 decoder
mfx: mfxjpegdec: MFX JPEG decoder
mfx: mfxdecode: MFX Video Decoder
mfx: mfxvpp: MFX video postprocessing
mfx: mfxsinkelement: MFX sink
mfx: mfxsink: MFX Sink Bin
mfx: mfxh264enc: MFX H.264 encoder
mfx: mfxhevcenc: MFX H.265 encoder
mfx: mfxjpegenc: MFX JPEG encoder
mfx: mfxvc1parse: VC1 parser
However , when I tested gst using mfxh264dec , I got following error, I googled the error but got no useful info for this.
# gst-launch-1.0 filesrc location=./Clip_1080_5sec_10mbps_h264.mp4 ! qtdemux ! h264parse ! mfxh264dec ! fakesink
Error Output:
Setting pipeline to PAUSED ...
libva info: VA-API version 1.3.0
libva info: va_getDriverName() returns -1
libva info: User requested driver 'iHD'
libva info: Trying to open /usr/local/lib/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_3
DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument
Assuming 131072kB available aperture size.
May lead to reduced performance or incorrect rendering.
get chip id failed: -1 [22]
param: 4, val: 0
libva error: /usr/local/lib/dri/iHD_drv_video.so init failed
libva info: va_openDriver() returns 1
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstMfxDec_h264:mfxdec_h264-0: Could not initialize supporting library.
Additional debug info:
gstvideodecoder.c(2492): gst_video_decoder_change_state (): /GstPipeline:pipeline0/GstMfxDec_h264:mfxdec_h264-0:
Failed to open decoder
Setting pipeline to NULL ...
Freeing pipeline ...
Following info is command "inxi -G and clinfo" outputs and /etc/X11/xorg.conf content。
#inxi -G
Graphics: Card-1: Intel Device 3e92
Card-2: NVIDIA Device 1b80
Display Server: N/A driver: nvidia tty size: 231x59 Advanced Data: N/A out of X
#clinfo
param: 4, val: 0
Number of platforms 2
Platform Name NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 1.2 CUDA 9.2.210
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store
cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
Platform Extensions function suffix NV
Platform Name Intel Gen OCL Driver
Platform Vendor Intel
Platform Version OpenCL 1.2 beignet 1.1.1
Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_spir
cl_khr_icd
Platform Extensions function suffix Intel
param: 4, val: 0
beignet-opencl-icd: no supported GPU found, this is probably the wrong opencl-icd package for this hardware
(If you have multiple ICDs installed and OpenCL works, you can ignore this message)
Number of devices 1
Device Name GeForce GTX 1080
Device Vendor NVIDIA Corporation
Device Vendor ID 0x10de
Device Version OpenCL 1.2 CUDA
Driver Version 396.54
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
Device Profile FULL_PROFILE
Device Topology (NV) PCI-E, 01:00.0
Max compute units 20
Max clock frequency 1809MHz
Compute Capability (NV) 6.1
Device Partition (core)
Max number of sub-devices 1
Supported partition types None
Max work item dimensions 3
Max work item sizes 1024x1024x64
Max work group size 1024
Preferred work group size multiple 32
Warp size (NV) 32
Preferred / native vector sizes
char 1 / 1
short 1 / 1
int 1 / 1
long 1 / 1
half 0 / 0 (n/a)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Support is emulated in software No
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Correctly-rounded divide and sqrt operations No
Address bits 64, Little-Endian
Global memory size 8510701568 (7.926GiB)
Error Correction support No
Max memory allocation 2127675392 (1.982GiB)
Unified memory for Host and Device No
Integrated memory (NV) No
Minimum alignment for any data type 128 bytes
Alignment of base address 4096 bits (512 bytes)
Global Memory cache type Read/Write
Global Memory cache size 327680
Global Memory cache line 128 bytes
Image support Yes
Max number of samplers per kernel 32
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 2048 images
Max 2D image size 16384x32768 pixels
Max 3D image size 16384x16384x16384 pixels
Max number of read image args 256
Max number of write image args 16
Local memory type Local
Local memory size 49152 (48KiB)
Registers per block (NV) 65536
Max constant buffer size 65536 (64KiB)
Max number of constant args 9
Max size of kernel argument 4352 (4.25KiB)
Queue properties
Out-of-order execution Yes
Profiling Yes
Prefer user sync for interop No
Profiling timer resolution 1000ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Kernel execution timeout (NV) Yes
Concurrent copy and kernel execution (NV) Yes
Number of async copy engines 2
printf() buffer size 1048576 (1024KiB)
Built-in kernels
Device Available Yes
Compiler Available Yes
Linker Available Yes
Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store
Number of devices 0
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) No platform
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) No platform
clCreateContext(NULL, ...) [default] No platform
clCreateContext(NULL, ...) [other] Success [NV]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) No platform
# cat /etc/X11/xorg.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0@0:2:0"
Option "AccelMethod" "None"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1@0:0:0"
Option "ConstrainCursor" "off"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration" "on"
Option "IgnoreDisplayDevices" "CRT"
EndSection
#lspci
00:00.0 Host bridge: Intel Corporation Device 3ec2 (rev 07)
00:01.0 PCI bridge: Intel Corporation Sky Lake PCIe Controller (x16) (rev 07)
00:02.0 Display controller: Intel Corporation Device 3e92
00:08.0 System peripheral: Intel Corporation Sky Lake Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Device a2af
00:14.2 Signal processing controller: Intel Corporation Device a2b1
00:16.0 Communication controller: Intel Corporation Device a2ba
00:17.0 SATA controller: Intel Corporation Device a282
00:1c.0 PCI bridge: Intel Corporation Device a290 (rev f0)
00:1c.3 PCI bridge: Intel Corporation Device a293 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device a2c9
00:1f.2 Memory controller: Intel Corporation Device a2a1
00:1f.3 Audio device: Intel Corporation Device a2f0
00:1f.4 SMBus: Intel Corporation Device a2a3
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1b80 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10f0 (rev a1)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
#ll /sys/class/graphics/
total 0
drwxr-xr-x 2 root root 0 10月 9 21:49 ./
drwxr-xr-x 66 root root 0 10月 9 21:41 ../
lrwxrwxrwx 1 root root 0 10月 9 21:41 fb0 -> ../../devices/platform/efi-framebuffer.0/graphics/fb0/
lrwxrwxrwx 1 root root 0 10月 9 21:44 fb1 -> ../../devices/pci0000:00/0000:00:02.0/graphics/fb1/
lrwxrwxrwx 1 root root 0 10月 9 21:41 fbcon -> ../../devices/virtual/graphics/fbcon/
Please help me , what should I do ?
Could it be that BIOS not configured or driver not right or something else?
I found someone said that's opencl render error about x11 because I have two GPUs. I dont know what that mean.
How can i use intel iGPU and nvidia GPU simultaneously?
