Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to read / write pipe in order with different workgroups and CUs?
Hello~
 i am trying to use Pipe in OpenCL2.0, but in my code I use many different workgroups and CUs.
I have defined below attribute
__attribute__((num_compute_units(2)))
In my code  it produces random values and put into different workgroups , for example 2 workgroups of 4x4 dimension each ,
write into the pipe, and then read from the pipe.
 I found that that when CU = 1, values write and read from pipe are in order, but when CU > 2, write / read are not in order.
Does anyone has idea about how to read / write pipe in order with many different workgroups and CUs?
Thanks in advance!
Highlighted
Which compiler are you using?
Highlighted
Hi AlexC,
-MichaelC
