[ailick@Ailick_Mj opencl]$ optirun clinfo drm_intel_gem_bo_context_exec() failed: No space left on device Number of platforms 3 Platform Name Intel Gen OCL Driver Platform Vendor Intel Platform Version OpenCL 2.0 beignet 1.3 Platform Profile FULL_PROFILE Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short cl_khr_gl_sharing Platform Extensions function suffix Intel Platform Name NVIDIA CUDA Platform Vendor NVIDIA Corporation Platform Version OpenCL 1.2 CUDA 8.0.0 Platform Profile FULL_PROFILE Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer Platform Extensions function suffix NV Platform Name Experimental OpenCL 2.1 CPU Only Platform Platform Vendor Intel(R) Corporation Platform Version OpenCL 2.1 LINUX Platform Profile FULL_PROFILE Platform Extensions cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer Platform Host timer resolution 1ns Platform Extensions function suffix INTEL Platform Name Intel Gen OCL Driver Number of devices 1 Device Name Intel(R) HD Graphics Haswell GT2 Mobile Device Vendor Intel Device Vendor ID 0x8086 Device Version OpenCL 1.2 beignet 1.3 Driver Version 1.3 Device OpenCL C Version OpenCL C 1.2 beignet 1.3 Device Type GPU Device Available Yes Device Profile FULL_PROFILE Max compute units 20 Max clock frequency 1000MHz Device Partition (core) Max number of sub-devices 1 Supported partition types None, None, None Max work item dimensions 3 Max work item sizes 512x512x512 Max work group size 512 Compiler Available Yes Linker Available Yes Preferred work group size multiple 16 Preferred / native vector sizes char 16 / 8 short 8 / 8 int 4 / 4 long 2 / 2 half 0 / 8 (n/a) float 4 / 4 double 0 / 2 (n/a) Half-precision Floating-point support (n/a) Single-precision Floating-point support (core) Denormals No Infinity and NANs Yes Round to nearest Yes Round to zero No Round to infinity No IEEE754-2008 fused multiply-add No Support is emulated in software No Correctly-rounded divide and sqrt operations No Double-precision Floating-point support (n/a) Address bits 32, Little-Endian Global memory size 2147483648 (2GiB) Error Correction support No Max memory allocation 1610612736 (1.5GiB) Unified memory for Host and Device Yes Minimum alignment for any data type 128 bytes Alignment of base address 1024 bits (128 bytes) Global Memory cache type Read/Write Global Memory cache size 8192 (8KiB) Global Memory cache line 64 bytes Image support Yes Max number of samplers per kernel 16 Max size for 1D images from buffer 65536 pixels Max 1D or 2D image array size 2048 images Base address alignment for 2D image buffers 4096 bytes Pitch alignment for 2D image buffers 1 bytes Max 2D image size 8192x8192 pixels Max 3D image size 8192x8192x2048 pixels Max number of read image args 128 Max number of write image args 8 Local memory type Local Local memory size 65536 (64KiB) Max constant buffer size 134217728 (128MiB) Max number of constant args 8 Max size of kernel argument 1024 Queue properties Out-of-order execution No Profiling Yes Prefer user sync for interop Yes Profiling timer resolution 80ns Execution capabilities Run OpenCL kernels Yes Run native kernels Yes printf() buffer size 1048576 (1024KiB) Built-in kernels __cl_copy_region_align4;__cl_copy_region_align16;__cl_cpy_region_unalign_same_offset;__cl_copy_region_unalign_dst_offset;__cl_copy_region_unalign_src_offset;__cl_copy_buffer_rect;__cl_copy_image_1d_to_1d;__cl_copy_image_2d_to_2d;__cl_copy_image_3d_to_2d;__cl_copy_image_2d_to_3d;__cl_copy_image_3d_to_3d;__cl_copy_image_2d_to_buffer;__cl_copy_image_3d_to_buffer;__cl_copy_buffer_to_image_2d;__cl_copy_buffer_to_image_3d;__cl_fill_region_unalign;__cl_fill_region_align2;__cl_fill_region_align4;__cl_fill_region_align8_2;__cl_fill_region_align8_4;__cl_fill_region_align8_8;__cl_fill_region_align8_16;__cl_fill_region_align128;__cl_fill_image_1d;__cl_fill_image_1d_array;__cl_fill_image_2d;__cl_fill_image_2d_array;__cl_fill_image_3d; Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short cl_khr_gl_sharing Platform Name NVIDIA CUDA Number of devices 1 Device Name GeForce GTX 760M Device Vendor NVIDIA Corporation Device Vendor ID 0x10de Device Version OpenCL 1.2 CUDA Driver Version 375.82 Device OpenCL C Version OpenCL C 1.2 Device Type GPU Device Available Yes Device Profile FULL_PROFILE Device Topology (NV) PCI-E, 01:00.0 Max compute units 4 Max clock frequency 719MHz Compute Capability (NV) 3.0 Device Partition (core) Max number of sub-devices 1 Supported partition types None Max work item dimensions 3 Max work item sizes 1024x1024x64 Max work group size 1024 Compiler Available Yes Linker Available Yes Preferred work group size multiple 32 Warp size (NV) 32 Preferred / native vector sizes char 1 / 1 short 1 / 1 int 1 / 1 long 1 / 1 half 0 / 0 (n/a) float 1 / 1 double 1 / 1 (cl_khr_fp64) Half-precision Floating-point support (n/a) Single-precision Floating-point support (core) Denormals Yes Infinity and NANs Yes Round to nearest Yes Round to zero Yes Round to infinity Yes IEEE754-2008 fused multiply-add Yes Support is emulated in software No Correctly-rounded divide and sqrt operations Yes Double-precision Floating-point support (cl_khr_fp64) Denormals Yes Infinity and NANs Yes Round to nearest Yes Round to zero Yes Round to infinity Yes IEEE754-2008 fused multiply-add Yes Support is emulated in software No Correctly-rounded divide and sqrt operations No Address bits 64, Little-Endian Global memory size 2098724864 (1.955GiB) Error Correction support No Max memory allocation 524681216 (500.4MiB) Unified memory for Host and Device No Integrated memory (NV) No Minimum alignment for any data type 128 bytes Alignment of base address 4096 bits (512 bytes) Global Memory cache type Read/Write Global Memory cache size 65536 (64KiB) Global Memory cache line 128 bytes Image support Yes Max number of samplers per kernel 32 Max size for 1D images from buffer 134217728 pixels Max 1D or 2D image array size 2048 images Max 2D image size 16384x16384 pixels Max 3D image size 4096x4096x4096 pixels Max number of read image args 256 Max number of write image args 16 Local memory type Local Local memory size 49152 (48KiB) Registers per block (NV) 65536 Max constant buffer size 65536 (64KiB) Max number of constant args 9 Max size of kernel argument 4352 (4.25KiB) Queue properties Out-of-order execution Yes Profiling Yes Prefer user sync for interop No Profiling timer resolution 1000ns Execution capabilities Run OpenCL kernels Yes Run native kernels No Kernel execution timeout (NV) Yes Concurrent copy and kernel execution (NV) Yes Number of async copy engines 1 printf() buffer size 1048576 (1024KiB) Built-in kernels Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer Platform Name Experimental OpenCL 2.1 CPU Only Platform Number of devices 1 Device Name Intel(R) Core(TM) i7-4710MQ CPU @ 2.50GHz Device Vendor Intel(R) Corporation Device Vendor ID 0x8086 Device Version OpenCL 2.1 (Build 10) Driver Version 1.2.0.10 Device OpenCL C Version OpenCL C 2.0 Device Type CPU Device Available Yes Device Profile FULL_PROFILE Max compute units 8 Max clock frequency 2500MHz Device Partition (core) Max number of sub-devices 8 Supported partition types by counts, equally, by names (Intel) Max work item dimensions 3 Max work item sizes 8192x8192x8192 Max work group size 8192 Compiler Available Yes Linker Available Yes Preferred work group size multiple 128 Max sub-groups per work group 1 Preferred / native vector sizes char 1 / 32 short 1 / 16 int 1 / 8 long 1 / 4 half 0 / 0 (n/a) float 1 / 8 double 1 / 4 (cl_khr_fp64) Half-precision Floating-point support (n/a) Single-precision Floating-point support (core) Denormals Yes Infinity and NANs Yes Round to nearest Yes Round to zero No Round to infinity No IEEE754-2008 fused multiply-add No Support is emulated in software No Correctly-rounded divide and sqrt operations No Double-precision Floating-point support (cl_khr_fp64) Denormals Yes Infinity and NANs Yes Round to nearest Yes Round to zero Yes Round to infinity Yes IEEE754-2008 fused multiply-add Yes Support is emulated in software No Correctly-rounded divide and sqrt operations No Address bits 64, Little-Endian Global memory size 12521263104 (11.66GiB) Error Correction support No Max memory allocation 3130315776 (2.915GiB) Unified memory for Host and Device Yes Shared Virtual Memory (SVM) capabilities (core) Coarse-grained buffer sharing Yes Fine-grained buffer sharing Yes Fine-grained system sharing Yes Atomics Yes Minimum alignment for any data type 128 bytes Alignment of base address 1024 bits (128 bytes) Preferred alignment for atomics SVM 64 bytes Global 64 bytes Local 0 bytes Max size for global variable 65536 (64KiB) Preferred total size of global vars 65536 (64KiB) Global Memory cache type Read/Write Global Memory cache size 262144 (256KiB) Global Memory cache line 64 bytes Image support Yes Max number of samplers per kernel 480 Max size for 1D images from buffer 195644736 pixels Max 1D or 2D image array size 2048 images Base address alignment for 2D image buffers 64 bytes Pitch alignment for 2D image buffers 64 bytes Max 2D image size 16384x16384 pixels Max 3D image size 2048x2048x2048 pixels Max number of read image args 480 Max number of write image args 480 Max number of read/write image args 480 Max number of pipe args 16 Max active pipe reservations 32767 Max pipe packet size 1024 Local memory type Global Local memory size 32768 (32KiB) Max constant buffer size 131072 (128KiB) Max number of constant args 480 Max size of kernel argument 3840 (3.75KiB) Queue properties (on host) Out-of-order execution Yes Profiling Yes Local thread execution (Intel) Yes Queue properties (on device) Out-of-order execution Yes Profiling Yes Preferred size 4294967295 (4GiB) Max size 4294967295 (4GiB) Max queues on device 4294967295 Max events on device 4294967295 Prefer user sync for interop No Profiling timer resolution 1ns Execution capabilities Run OpenCL kernels Yes Run native kernels Yes Sub-group independent forward progress No IL version SPIR-V_1.0 SPIR versions 1.2 printf() buffer size 1048576 (1024KiB) Built-in kernels Device Extensions cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer NULL platform behavior clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Intel Gen OCL Driver clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [Intel] clCreateContext(NULL, ...) [default] Success [Intel] clCreateContext(NULL, ...) [other] Success [NV] clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1) Platform Name Intel Gen OCL Driver Device Name Intel(R) HD Graphics Haswell GT2 Mobile clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1) Platform Name Intel Gen OCL Driver Device Name Intel(R) HD Graphics Haswell GT2 Mobile ICD loader properties ICD loader Name OpenCL ICD Loader ICD loader Vendor OCL Icd free software ICD loader Version 2.2.11 ICD loader Profile OpenCL 2.1
[ailick@Ailick_Mj ~]$ sudo pacman -Qs opencl local/beignet 1.3.1-3 An open source OpenCL implementation for Intel IvyBridge+ iGPUs local/clinfo 2.1.17.02.09-1 A simple OpenCL application that enumerates all available platform and device properties local/intel-opencl-sdk 2017_7.0.0.2511-1 Intel SDK for OpenCL Applications Linux* 2017 And OpenCL runtime for Intel Core and Xeon processors local/ocl-icd 2.2.11-1 OpenCL ICD Bindings local/opencl-headers 2:2.2.20170516-1 OpenCL (Open Computing Language) header files local/opencl-nvidia 1:375.82-1 OpenCL implemention for NVIDIA
Why it always telling me that drm_intel_gem_bo_context_exec() failed: No space left on device ? If anyone could help me?
