Community
cancel
Showing results for
Search instead for
Did you mean:
diffent
Install erorr: Intel SDK for OpenCL on Amazon AWS node Windows
Hi all, I am getting an error trying to install the new 2013 OpenCL SDK on an Amazon AWS node.
The error msg says that the OS is not WIndows Server 2008 R2, but I think it actually is.  Has anyone
seen this error or know of a solution?  Attached error msg snapshot from the Intel installer.
Yuri_K_Intel
Hi, Could you please also provide the 'install.log' that is referenced in the error message? Thanks, Yuri
diffent
Hello, I have solved the problem yesterday.  I was using Windows Server 2008 R1 SP2 but the SDK needs R2 SP1.  Thanks for your response.
