OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Installation problem openCL sdk
gagliano__luca
Hello everyone,
I'm new to this forum. I managed to install openCL sdk on windows, with no problem. I need to do the same thing for linux though, but I can't manage to install it. More details are given here: https://stackoverflow.com/questions/50650173/ubuntu-16-04-opencl-sdk-installation-apt-get-update-fails
Any chance you can help me with this? not sure If I have an authentication issue or not.
Michael_C_Intel1
Hi LucaG,
Can you indicate where you were blocked? This link was not found. Not sure what is being communicated in your post by "authentication".
https://software.intel.com/en-us/articles/sdk-for-opencl-gsg (Step2) has some guidance... but specifics may vary system to system. Starting from ./install.sh or ./install_GUI.sh is good... the installers should give most of the required feedback for dependencies desired and required.
The exception is the eclipse plugin which has a few dependencies listed on the gsg page. The java components are because the plugin front end is implemented in java, dkms and lsbcore components are for the plugins to interface through the driver stack, libicu is for charactersets, and mono is required due to the nature of the implementation. These packages are referenced in the example script file on that page.
-MichaelC
