OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Installing Intel OpenCL in centOS
Srivanam_Segar
Trying to installintel_ocl_sdk_1.5_x64.rpmin a centOS machine
uname -s -r -v -m -p -i -o :
Linux 2.6.18-194.el5 #1 SMP Fri Apr 2 14:58:14 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
Should I expect to fail when installing?
The fact is, *prior* to installing these dependency errors happen:
rpm -iintel_ocl_sdk_1.5_x64.rpm
error: Failed dependencies:
libnuma.so.1(libnuma_1.1)(64bit) is needed by intel-ocl-sdk-1.5-15293.x86_64
libnuma.so.1(libnuma_1.2)(64bit) is needed by intel-ocl-sdk-1.5-15293.x86_64
libstdc++.so.6(GLIBCXX_3.4.10)(64bit) is needed by intel-ocl-sdk-1.5-15293.x86_64
libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by intel-ocl-sdk-1.5-15293.x86_64
Both libnuma.so.1 and libstdc++.so.6 are in /usr/lib64.
Any hint on what am I overlooking for ?
nurbs
I think there is a flag you can use to ignore the dependency check. I remembered I saw thesame error, andsomehow I wasable toget through that step.
