OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Intel OpenCL SDK 2013 debugger - "-g -s" Build option
Micha_M_
I'm trying to debug an OpenCL kernel using the Intel OpenCL SDK  2013 debugger integrated in VS2010 and Windows 7 64-bit.
The documentation states I have to pass "-g -s
" as an option to clBuildProgram() but this results in a CL_BUILD_ERROR error
I've tried these two options:
1.   m_clStatus = ::clBuildProgram(m_clProgram,
                                  1,
                                  &m_clDeviceId,
                                   "-g -s m:/kernels/My_kernel.cl",
                                   NULL, NULL);
2.   m_clStatus = ::clBuildProgram(m_clProgram,
                                  0,
                                  NULL,
                                   NULL, NULL);
Is it correct?
The compilation succeed if the target device is IGPU.
Micha
Raghupathi_M_Intel
The fourth option to clBuildProgram() specifies the build options. So you should be passing "-g -s" and you don't need the "m:/kernels/My_kernel.cl" string.
Raghu
Micha_M_
Thank you,
Do you mean
                                  1,
                                  &m_clDeviceId,
                                   "-g -s",
                                   NULL, NULL);
This command returns error code -43 (= CL_INVALID_BUILD_OPTIONS).
Micha
Yuri_K_Intel
Hi Micha, Actually, you need to specify full path to your kernel in -s option, so please pass "-g -s m:/kernels/My_kernel.cl" for build options. Please also make sure that you create a context with CPU device only, since debugging doesn't work for GPU device currently. Here is documentation http://software.intel.com/sites/products/documentation/ioclsdk/2013/UG/Debugging_Your_OpenCL_Kernel_with_Intel_SDK_for_OpenCL_Debugger.htm In case you still have a problem, please attach a small reproducer. Thanks, Yuri
Raghupathi_M_Intel
Ah, sorry. Yuri is correct you do need the complete path to your kernel. Please post if you are still having trouble after following his suggestions.
Raghu
