Hi
i am sorry if the issue has been discussed before, but i couldn't find the solution the problem i am facing.
I am running a simple vector_add openCL code through emulator for Intel FPGA SDK for openCL. The issue i am facing is that the program cannot find CL_DEVICE("ERROR: CL_DEVICE_NOT_FOUND "). where as if i run a helloworld program using intel SDK for OpenCL, it runs seamlessly.
the example code is here
Please help me make devices visible for intel FPGA SDK for openCL
jeveria
Hi JeveriaM,
Thanks for sharing your bring up concerns...
Can you indicate:
- What Intel FPGA Device you're using?
- Which OS you're using?
- Which driver for FPGA you're using?
- Which Intel OpenCL SDK for FPGA distribution you're using?
- Which Intel OpenCL SDK for CPU SDK you're using?
-MichaelC
