OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
KernelBuilderAPI.dll
peter_b_8
Dears,
I am running Visual Studio Community 2015 on WIndows 7, 64bit.
===================================[ System / CPU ]
- CPU Name: Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
- CPU Core Speed: 2594 MHz
- CPU logical cores: 4
- Family: 6 - Model: 12 - Stepping: 3
- Physical Memory Size: 8192 MB
- Operating System: Windows 7 64-bit build 7601 [Service Pack 1]
- PhysX Version: drivers not installed
===================================[ OpenCL Capabilities ]
- Num OpenCL platforms: 2
- CL_PLATFORM_NAME: Intel(R) OpenCL
- CL_PLATFORM_VENDOR: Intel(R) Corporation
- CL_PLATFORM_VERSION: OpenCL 1.2
- CL_PLATFORM_PROFILE: FULL_PROFILE
- Num devices: 2
===================================[ OpenGL GPU Capabilities ]
- OpenGL vendor: Intel
- OpenGL renderer: Intel(R) HD Graphics 4600
- OpenGL Version: 4.2.0 - Build 10.18.10.3574
- GLSL (OpenGL Shading Language) Version: 4.20 - Build 10.18.10.3574
starting a OpenCL project I got
Code Builder initialization failed:
Unable to load DLL 'KernelBuilderAPI.dll': The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
Please help to fix it.
Thank you.
Robert_I_Intel
Peter, I am afraid you have a very outdated graphics driver (see the other post on how to get a newer version). Thanks!
Bilgesu_C_
I also have the same issue and I don't have a very outdated graphics driver (Intel HD Graphics 4000). Please fix this issue.
Yuval_E_Intel
Hi all,
From the error message it seems that from some reason there is a missing dll in your platform.
The missing dll is NOT KernelBuilderAPI.dll but another dll which is required for loading the KernelBuilderAPI.dll
You can try one of the following to find out which dll is missing:
1.  Run …\OpenCL SDK\bin\x86|x64\KernelBuilder32.exe from command line
2.  If it still doesn’t give you the name of the missing dll run …\OpenCL SDK\bin\x86|x64\GPUhelper.exe from command line
3. If it still doesn’t give you the name of the missing dll try to install this tool: http://www.dependencywalker.com/.  And run
        depends "...\OpenCL SDK\bin\x86|x64\KernelBuilderAPI.dll"
 When you have the name of the missing dll please post it in the forum so we can help fixing the issue.
Thanks, Yuval
peter_b_8
Hi Yuval,
option 1) & 2) don't work for me.
I did 3) dependencywalker:
In the case of KernelBuilderAPI.dll (x64) those dll's missing:
API-MS-WIN-CORE-WINRT-ERROR-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ROBUFFER-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-STRING-L1-1-0.DLL
DCOMP.DLL
IESHIMS.DLL
In the case x86 dll's missing:
DCOMP.DLL
GPSVC.DLL
IESHIMS.DLL
Please see attached "dependency walker image" .
Peter
peter_b_8
BTW pls don't be misled by dependencywalker for fixing issue
http://stackoverflow.com/questions/17023419/win-7-64-bit-dll-problems
Comment from t:
Windows 7 kernel changes that led to api-ms-win-* DLLs are explained quite well over herenirsoft.net/articles/windows_7_kernel_architecture_changes.html - i think DependencyWalker just cant handle these changes - so dont worry about those too much. From MS: msdn.microsoft.com/en-us/library/hh802935%28v=vs.85%29.aspx – x29a May 15 '14 at 4:41
Yuval_E_Intel
Hi Peter,
You're right, the missing dlls that dependencywalker specified are not the issue.
I notice that the error is not about missing dll but a missing procedure ("The specified procedure could not be found"). Sorry for the confusion.
My guess is that the OpenCL.dll that you have is 1.2 version when it should be 2.0.
Please do the following to check the version (see the attached picture):
1.    Go to C:\Windows\SysWOW64
2.    Right click on OpenCl.dll -> Properties -> Details and see the file version
3.    If it is not 2.0 please copy it manually from: C:\Program Files (x86)\Intel\OpenCL SDK\bin\icd\x86\OpenCL.dll
(It should be done by the SDK installer)
Thanks, Yuval
peter_b_8
Many thanks!
I got  OpenCL.dll of 2.0.2.0 version now at C:\Windows\SysWOW64 . Now it works fine.
Thank you!
karen_d_
Hi Yuval;
I'm running Visual Studio 2015 on a Window 7 Pro, SP1 (64 bit)
Processor: Intel Core I7-4800MQ CPU with 8GB ram
Graphics:   Intel HD Graphics 4600, driver version is 10.18.19.3412 (Jan 29, 2014)
I downloaded the OpenCL 2.0 sdk from "https://software.intel.com/en-us/intel-opencl/download".
File downloaded is: "intel_sdk_for_opencl_setup_6.0.0.1049.exe".
I had exactly the same errors as peter b and followed all instructions including copying OpenCL.dll from the SDK directory to Windows\SysWOW64.  However unlike peter b's happy ending, when I run Visual Studio it spits out an error: "Code Builder initialization failed: An attempt was made to load a program with an incorrect format.(Exception from HRESULT:0x8007000B)"
I don't even have any code that references the OpenCL dll yet (at least that I'm aware of).
I really only need OpenCL 2.0 runtime, but couldn't find where to download only the runtime verion.
Any help would be greatly appreciated as I'm STUCK.
Karen D
Uri_L_Intel
Hi Karen,
OpenCL 2.0 is not support on Intel HD 4600.
It is supported on 5th generation of Intel® Core processors and later (you can see the full support matrix on our release notes: https://software.intel.com/en-us/articles/opencl-code-builder-release-notes)
You can work with the OCL2.1 experimental CPU only runtime that comes with the SDK – see more details here: https://software.intel.com/en-us/node/539396
Please try to install the latest SDK version (6.1.0.1600) and see if you’re still getting these error messages.
Uri
karen_d_
Hi Uri;
Thanks for the info.  I may try this later, but due to the project deadline, can't afford the time to use an experimental version.  I'll be testing on a machine that has a GPU.
It would be convenient to be able to run on the machine that doesn't have one, but I just don't think I've got the time to troubleshoot.
When I do try it I'll let you guys know how it turned out.
Karen
