Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
[NOT SOLVED] ioc64: simple kernel killed
A kernel which works perfectly well under Mali GPU, does not compile under Intel GPU.
ioc64 -cmd=build -input=TestKernel.cl -device=gpu -ir=TestKernel.bin hangs and then operation is killed.
If I specify -device=cpu, it works.
I also tried to load the kernel as source, instead as binary, but it hangs as well.
If I take out the return from C6, or some other particular lines of code, it compiles.It's driving me mad.
Highlighted
Thanks for this report.  The kernel compiles for GPU with Windows ioc64 but not Linux.  This seems to be a bug.  I've filed it for the dev team.
Highlighted
Hi Jeffrey,
Thanks. The problem is not ioc64 but most probably the Intel gpu, that is because I tried to load the kernel without compile it to binary, so WithSource instead of WithBinary. I also tried gcc, icc, Intel sdk and amd sdk and the issue remains. The most strange thing is that, by commenting out some lines, it works.
Highlighted
The behavior reported with ioc64 is not as expected, so we will continue to work on improving it.  Glad you have a workaround.
Highlighted
Hi Jeffrey,
Thanks for that, I do not have a workaround, I'm just saying that if I comment random lines, it compiles, but then the kernel is useless.
I'm waiting until Intel fix the issue, please fix it as soon as possible, as I am stuck. It must be the i915 driver.
