Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New SDK install fails with symbol lookup error when building kernel code
I'm quite new to OpenCL and parallel computing in general.
I have just installed the SDK on a Linux SLES11 computer with a Core i7-4770 Processor.
Files installed were intel_sdk_for_ocl_applications_2014_4.6.0.92_x64.tgz and opencl_runtime_14.2_x64_4.5.0.8.tgz.
I've tried running two tests, first the sample code for general matrix multiply, and second a simple program to perform an addition and print out the processors capabilities, like MAX_COMPUTEEE_UNITS, MAX_WORK_GROUP_SIZE, etc.  They both fail upon trying to compile the kernel, with the following message:
symbol lookup error: /opt/intel/opencl-1.2-4.5.0.8/lib64/libclang_compiler.so: undefined symbol: _ZN5Intel6OpenCL5Utils6Logger11GetInstanceEv, version Base
I guess it's looking for a library it can't find?  Which one, and how to fix this problem.
Thanks, Bob
Highlighted
We are having the exact same problem since upgrading our Intel OpenCL runtime to the latest version in opencl_runtime_14.2_x64_4.5.0.8.tgz.
Our application now fails with the error:
trade_pricer: symbol lookup error: /apps/tools/toolset10/Linux.3.0.101-0.35-default.x86_64/opencl-1.2-4.5.0.8/lib64/libclang_compiler.so: undefined symbol: _ZN5Intel6OpenCL5Utils6Logger11GetInstanceEv, version Base
where previously it was working fine.
To me this looks there is something wrong with the Intel opencl-1.2-4.5.0.8 runtime build. The missing symbol is part ot the Intel::OpenCL namespace,i.e.
> echo _ZN5Intel6OpenCL5Utils6Logger11GetInstanceEv | c++filt
Intel::OpenCL::Utils::Logger::GetInstance()
It appears that readelf confirms the symbol is referenced in the packaged libclang_compiler.so shared library:
> readelf -Ws libclang_compiler.so | grep GetInstance | grep Logger
   361: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _ZN5Intel6OpenCL5Utils6Logger11GetInstanceEv@Base (14)
And also that it is defined in the packaged libcl_logger.so shared library:
> readelf -Ws libcl_logger.so | grep GetInstance
   270: 0000000000008530    11 FUNC    GLOBAL DEFAULT   13 _ZN5Intel6OpenCL5Utils6Logger11GetInstanceEv@@Base
So there is something very strange going on here.
Can someone at Intel please investigate whether there is a problem with the libraries pakcaged in opencl_runtime_14.2_x64_4.5.0.8.tgz?
Thanks!
Andy
Highlighted
Hi Robert and Andy, Sorry for this issue. I didn't try to reproduce it yet, but here is one possible workaround. Are you targeting CPU only for OpenCL development? Did you install OpenCL runtime (from opencl_runtime_14.2_x64_4.5.0.8.tgz) by default (with all options)? If answers to both questions are yes, then could you please reinstall OpenCL runtime, but for CPU only (i.e. don't install runtime for Intel® Xeon Phi(TM) coprocessor device). On 'Step 4 of 6 | Options > Pre-install Summary' choose '2. Customize installation', then '3. Change components to install', '3' to deselect 'OpenCL™ runtime for Intel® Xeon Phi(TM) coprocessor device', 'Enter', 'Enter'. Thanks, Yuri
Highlighted
Thanks for your prompt suggestion, Yuri.
This has corrected the issue for me and I can now get our application to run with the OpenCL runtime package installed in the manner you have specified.
Andy
Highlighted
Thanks Yuri, indeed this takes care of the problem.
Bob
