OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
OPENCL Kernel Debugging
KI_JU_L_
When I use __local space qualifier, I couldn't debug inside kernel.
1. Is there anyone, who has same experience?
2. Is there any method to avoid this phenomena?
Raghupathi_M_Intel
Were you able to debug before adding the qualifier? Can you attach your kernel?
Raghu
KI_JU_L_
Thank you Raghu,
I usually set break point at line 404 in Bitonic_APU.cl
I can break on this point. but I cannot debug or trace further more after line 404.
Could you give me the information, whether my mis-usage or not
Thanks again.
KI_JU_L_
Dear Raghu,
Do you know how can I delete my comments?
Raghupathi_M_Intel
Above your post you should see an "Edit" link. Click that and see if you have a "delete" button.
Raghu
