Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
OpenCL kernel source file to C char string converter
Hi !
I have made this nice OpenCL kernel source code file to C/C++ char string converter:
https://github.com/MatejGomboc/OpenC...ring-converter
I hope you will find it useful !
Best regards.
Highlighted
Hi MatejG,
Haven't tried it, but I took a quick peek through your py script & repo. Tools like this could go a long way to eliminating a tedious task for developers bringing up their kernels.
Thanks for the reference.
-MichaelC
Highlighted
Another option is to use your compiler's preprocessor and a utility like xxd to produce an includable source or binary kernel.
To create an includable file of source kernels:
  • <compiler> -I . -I "%INTELOCLSDKROOT%\include" -D <opencl defines> -EP <input .cl> -P <preprocessed .cl>
  • dos2unix -q <preprocessed .cl>
  • xxd -i <preprocessed .cl> <preprocessed .h>
To create an includable file of binary kernels:
  • ioc64 -cmd=build -bo=<opencl build options> -device=gpu -input=<preprocessed .cl> -ir <binary .ir>
  • xxd -i <binary .ir> <binary include file>
Then just load the source or binary kernel(s) with the appropriate OpenCL functions.
