OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
OpenCV - Caffe - Object Detection - i3 NUC(8th Gen) - High CPU Util
Mounagurusamy__Guruv
Case 1: OpenCV - Caffe - Object Detection - i3 NUC(8th Gen) - High CPU Util
I am building an object detection solution using CCTV Cameras, using intel i3 NUC(8th Gen).
I have installed the following libraries: https://software.intel.com/content/www/us/en/develop/articles/intel-parallel-studio-xe-runtime-by-version.html
Also, I have installed Intel Neo OpenCL and I am calling the following to execute using OpenCL:
net.setPreferableBackend(cv.dnn.DNN_BACKEND_OPENCV)
net.setPreferableTarget(cv.dnn.DNN_TARGET_OPENCL)
But, I encounter the following warning while executing the code(with 76% CPU util for one CCTV Camera)
[ WARN:0] global /io/opencv/modules/dnn/src/dnn.cpp (1218) setUpNet DNN: OpenCL target is not supported with current OpenCL device (tested with GPUs only), switching to CPU.
I have also installed Beignet OpenCL
clinfo Details:
ioz@ioz-NUC8i3BEH:~/Desktop/CodeWrks/cam01$ clinfo
Number of platforms 1
Platform Name Intel Gen OCL Driver
Platform Vendor Intel
Platform Version OpenCL 2.0 beignet 1.3
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_spir cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short cl_khr_gl_sharing
Platform Extensions function suffix Intel
beignet-opencl-icd: no supported GPU found, this is probably the wrong opencl-icd package for this hardware
(If you have multiple ICDs installed and OpenCL works, you can ignore this message)
Number of devices 0
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Intel Gen OCL Driver
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Intel Gen OCL Driver
clCreateContext(NULL, ...) [default] No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) No devices found in platform
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.11
ICD loader Profile OpenCL 2.1
Can you please help me understand, why do I encounter high CPU despite using intel OpenCL, Do i need to do anything else to bring the CPU Util low?
Case 2: OpenCV-Caffe - Object Detection using CCTV Camera - GNA Plugin - Intel Pentium Silver Processor
On contrary to the above mentioned case, I was able to execute the object detection code for five CCTV cameras in Intel Pentium Silver(with GNA Plugin installed) and Average CPU util for five cameras is 60%
Is GNA Plugin makes the difference in CPU utilisation?
Note: I am not using the OpenVINO object detection code in both the systems
Can you please help me resolve this issue.
Guru
Luis_at_Intel
Hi Mounagurusamy__Guruv,
Thanks for reaching out. Based on your issue description the problem seems to rely on "Case 1: OpenCV - Caffe - Object Detection - i3 NUC(8th Gen) - High CPU Util", as your Case 2 with OpenVINO™ Toolkit seems to be working fine. Is my understanding correct? If so, I may have to redirect this thread to OpenCL* forum where you will receive guidance.
Based on the clinfo details "no supported GPU found, this is probably the wrong opencl-icd package for this hardware" it looks like is not detecting a GPU supported by opencl-icd, and its falling back to CPU. Do you have any additional details about the i3 NUC(8th Gen) NUC/processor? SKU number, for example NUC8i3BEH or Intel® Core™ i3 8109U processor.
Luis
Hi Luis,
1) For Case 2 - It's the Intel Silver Pentium J5005 processor and I have installed the OpenVINO GNA plugin, but I am not explicitly using OpenVINO for Code execution (I am using Caffe Object Detection in Python) - https://www.pyimagesearch.com/2017/09/18/real-time-object-detection-with-deep-learning-and-opencv/
But I have added the code to call Open CL (Beignet).
For Case 1 - I followed the same as Case 2, but GNA plugin couldn't be installed, but I have installed Beignet / Intel Neo.
Looks like both didn't work.
NUC Details - NUC8i3BEH, Intel® Core™ i3 8109U processor.
Guru
Hi intel team,
Can you please let me know, if GNA Plugin is the reason for the performance optimization in J5005 Pentium Silver processor?, I am not using OpenVINO Models or Code.
I am using the following code, cv.dnn.DNN_TARGET_OPENCL or cv.dnn.DNN_TARGET_CPU
I am using the following Code:
I am running the above code for five CCTV cameras, CPU Util is approx 60% on J5005 Pentium Silver.
If GNA Plugin Driver is the reason for the CPU performance optimization, Can you please confirm?
Guru
