Folks,
Can you help me clarify the reason for the following warning, running OpenCL.
OpenCV(ocl4dnn): consider to specify kernel configuration cache directory
via OPENCV_OCL4DNN_CONFIG_PATH parameter
Following is the code snippet added.
net.setPreferableBackend(cv.dnn.DNN_BACKEND_OPENCV)
net.setPreferableTarget(cv.dnn.DNN_TARGET_OPENCL_FP16)
I am executing, Object Detection Inference using OpenCV and Caffe.
System Details
OS: Ubuntu 16.04
Processor: Intel® Core™ i3-8109U CPU @ 3.00GHz × 4
Grpahics: Intel® HD Graphics (Coffeelake 3x8 GT3)
OpenCV: Version 4.0
OpenCL: Version 19.21.13045
Guru
Hi GuruV,
Thanks for the interest.
This issue was discussed on the OpenCV github. It may be useful to review that issue and submit follow up questions there if necessary.
-MichaelC
