Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Potential OpenCL compiler/implementation issue
I met issue when using work_group_all/sub_group_all. So I simplified into below kernel.
// kernel start
kernel void entry()
    int id = (int)get_global_id(0);
    bool end = false;
    int cnt = 0;
    bool end2 = false;  // always of the same value for the whole work/sub group
    while (1)
        if (end2) break;
        if (cnt==0)
            //  First loop
            end = id==0;    //  end is only true for first work item
        else
            //  Second loop
            end = true;     //  end is always true now
        //  end2 will be false at first loop, and true at second loop
        //  end2 will be of the same value for whole sub_group/work_group
#if 1
        end2 = sub_group_all(end?1:0)!=0;
#else
        end2 = work_group_all(end?1:0)!=0;
#endif
#if 1
        if ((id&0xff)<=1)
            printf("id = %d, cnt=%d, end = %d, end2 = %d\n", id, cnt, end?1:0, end2?1:0);
#endif
        cnt++;
// kernel end
The execution is just dead. Output shows the cnt will never be 2, but the kernel just not finished. No matter I use work_group_all() or sub_group_all().
id = 0, cnt=0, end = 1, end2 = 0
id = 1, cnt=0, end = 0, end2 = 0
id = 512, cnt=0, end = 0, end2 = 0
id = 513, cnt=0, end = 0, end2 = 0
id = 512, cnt=1, end = 1, end2 = 1
id = 513, cnt=1, end = 1, end2 = 1
My work item number is always power of 2, and bigger than 512.
When running on CPU, it just deadloop that I can kill through OS. When running on GPU, it will just lead to whole OS deadloop if I use work_group_all().
I tried with following two different OCL compiler version with same result:
Intel(R) SDK for OpenCL(TM) - Offline Compiler, version 8.0.0.171
Intel(R) SDK for OpenCL(TM) - offline compiler command line, version 7.0.0.3993
Tango
