OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Questions about Intel's opencl platform
Nikos_B_
I'm new to Intel's opencl platform, but have read good things about its performance.
I need to know if I am compatible with your platform, b4 venturing in too deep.
I use Ubuntu 14.04 x64. My card is a radeon Curacao Pro R9 270 2 GB, and my CPU is AMD FX 8320 8-core with 8 GB memory. Unfortunately, I cannot find a working opencl debugger from AMD (CodeXL 1.7 doesn't work and i cannot find earlier releases). So I was wandering if your platform could generate code for this setup, and if Code Builder could debug it.
Robert_I_Intel
CentOS or SLES are supported platforms. Intel does not have a discrete GPU, what we have is an accelerator Xeon Phi:
http://www.intel.com/content/www/us/en/processors/xeon/xeon-phi-detail.html
I am not familiar with Xeon Phi product line and how it compares to the competition: you will need to research this yourself.
Robert_I_Intel
Ubuntu is an unsupported platform, but you maybe able to install Intel's OpenCL runtime for the CPU, as other people succeeded doing that. As to whether it would work on AMD processors, again I am not sure, since this is an unsupported platform :) It will definitely not utilize your GPU: for that you need to go to AMD website.
Nikos_B_
Ty for your fast reply.
I have to use Linux for my work. I have read that Intel supports CentOS. I definitely need the GPU. I probably would have to buy an Intel card for that. Which one would you recommend similar to the radeon one i already have? I need it for DSP, real-time spectrum analyzer.
Robert_I_Intel
Nikos_B_
Interesting. Intel uses HPC, while AMD uses HSA. I could live with a Xeon Phi, although it represents a departure from what I am doing. I am concerned to use another general purpose processor, over many discrete number-crunching GPUs. Intel's performance metrics show a benefit of ~3.5x over a 2 CPU setup. That would roughly mean a max 7x benefit over a single multi-core CPU.  I have clocked my application running 10x faster than running from my 8-core CPU alone.
I am not sure about the performance with nvidia cards. I imagine that the metrics with nvidia cards, use nvidia's openCL.
However, the lack of AMD's debugging environment is critical. It is good to have more options. I will have to think it over.
Thanks again.
