OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
Some suggestions!
rtfss1gmail_com
Some suggestions for improving this good release:
For completeness:
*Add 3d_image_writes support as AMD GPU backend supports it and I have some demo using it..
*Add D3D10 interop: cl_khr_d3d10_sharing similar to OpenGL interop so some Nvidia/AMD samples work too..
comparing to AMD:
*Addcl_ext_device_fission so we can expose multiple concurrent kernels,etc..
more ambitious:
Add next-gen computing features (as featured in CUDA 3.x) :
*(support for no inlined functions with stack) brings Function pointers andRecursion : believe or not but Nvidia OCL GPU backend supports at least recursion! and function pointers fails only when building (also GPU ocelot cpu backend (PTX->LLVM) supports it right now!)
*Similar to printf expose malloc and free (featured new in CUDA 3.2)
Also seems AMD is working on some C++ support (templatized kernels)
What do you think?
Thank.
Ofer_Rosenberg__Inte
We would like to thank you for your suggestions.
Some of these suggestions have been raised internally as well, and are considered for the next versions of the SDK.
About the specific proposal to allow asm functions accessed directly inside kernels, I do not believe that we will want to go in this direction. Intel's direction is to promotethe cross-device approach of OpenCL, and this proposal goes against it. The preferred direction is improving the compiler, making sure that the mapping to assembler instructions is efficient. I believe that the additions made to the OCL C language improve the complier's ability to reach this goal.
However, the direction of adding new built-in functions, which map well to SSE instructions, is interesting. We do see cases where a code sequence can be efficiently replaced by a call to SSE instruction - and the method that we prefer is to expose it as a built-in function. this preserves the approach of C language, and is also forward compatible - on future ISA, this built-in can be replaced by the JIT complier in a new instruction.
rtfss1gmail_com
Another one:
*Allow asm("") function being able to insert x86 assembly code in kernels
CUDA allows asm function containing PTX code inside CUDA device functions..
rtfss1gmail_com
thanks for your insight.. as you say perhaps asm("") is not a good approach but I think the others are interesting still! Really waiting to see how this excellent SDK evolves!
