Is there an installation package for Ubuntu ?
If not, it will be nice to have, a lot of customers would like to run my soft. on Ubuntu with the Intel SDK !
Hi Nishma,
1. Could you run any other of the Intel samples? Do they run on the CPU device, and you just get the error messages in the output, as above?
2. Looks like fglrx is giving you trouble (https://en.wikipedia.org/wiki/AMD_Radeon_Software_Crimson#Linux ), but the Intel CPU driver is actually doing its thing. Somehow AMD driver does not play well with our driver or vice versa.
I have no way to replicate your hardware configurations. One thing you could try is to make sure that LD_LIBRARY_PATH, in addition to pointing to Intel OpenCL libraries, points to AMD ones as well. Check this out too https://elrepo.org/bugs/view.php?id=457
Hi Robert,
I uninstall AMD SDK and now no error is generated with clinfo and I got the following
Number of platforms: 1
Platform Profile: FULL_PROFILE
Platform Version: OpenCL 1.2 LINUX
Platform Name: Intel(R) OpenCL
Platform Vendor: Intel(R) Corporation
Platform Extensions: cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64
Number of devices: 1
Device Type: CL_DEVICE_TYPE_CPU
Vendor ID: 8086h
Max compute units: 4
Max work items dimensions: 3
Max work items[0]: 8192
Max work items[1]: 8192
Max work items[2]: 8192
Max work group size: 8192
Preferred vector width char: 1
Preferred vector width short: 1
Preferred vector width int: 1
Preferred vector width long: 1
Preferred vector width float: 1
Preferred vector width double: 1
Native vector width char: 16
Native vector width short: 8
Native vector width int: 4
Native vector width long: 2
Native vector width float: 4
Native vector width double: 2
Max clock frequency: 2530Mhz
Address bits: 64
Max memory allocation: 2056365056
Image support: Yes
Max number of images read arguments: 480
Max number of images write arguments: 480
Max image 2D width: 16384
Max image 2D height: 16384
Max image 3D width: 2048
Max image 3D height: 2048
Max image 3D depth: 2048
Max samplers within kernel: 480
Max size of kernel argument: 3840
Alignment (bits) of base address: 1024
Minimum alignment (bytes) for any datatype: 128
Single precision floating point capability
Denorms: Yes
Quiet NaNs: Yes
Round to nearest even: Yes
Round to zero: No
Round to +ve and infinity: No
IEEE754-2008 fused multiply-add: No
Cache type: Read/Write
Cache line size: 64
Cache size: 262144
Global memory size: 8225460224
Constant buffer size: 131072
Max number of constant args: 480
Local memory type: Global
Local memory size: 32768
Kernel Preferred work group size multiple: 128
Error correction support: 0
Unified memory for Host and Device: 1
Profiling timer resolution: 1
Device endianess: Little
Available: Yes
Compiler available: Yes
Execution capabilities:
Execute OpenCL kernels: Yes
Execute native function: Yes
Queue on Host properties:
Out-of-Order: Yes
Profiling : Yes
Platform ID: 0x1c9ceb0
Name: Intel(R) Core(TM) i5 CPU M 540 @ 2.53GHz
Device OpenCL C version: OpenCL C 1.2
Driver version: 1.2.0.10002
Version: OpenCL 1.2 (Build 10002)
Hi Nishma,
One thing I am curious about: if you reinstall the AMD SDK, does that fix the problem and do you see the GPU device as well?
Hi Robert,
I tried running GEMM and bitonic sort and it doesn't give error now. They use CPU. Does this means I have install OpenCL correctly? Could you please tell me how to run samples using GPU?
Nishma Laitonjam
Hi Nishma,
Yes, you installed the CPU OpenCL runtime correctly. You could try to reinstall AMD SDK and see if you could get your GPU OpenCL device back. Your integrated GPU is much too old, so we don't have an OpenCL runtime that supports it.
Hi Tata,
We don't support a GPU driver for Sandy Bridge. Sorry!
Hi Robert,
My environment is ubuntu14.04 64-bit and Intel® Core™ i7-4770 CPU @ 3.40GHz × 8.
I've download and installed the Intel opencl backend from https://software.intel.com/en-us/articles/opencl-drivers#latest_linux_driver.
Also I installed the clinfo: $ sudo apt-get install clinfo
And then I ran clinfo: $ sudo clinfo
But it crashed:
terminate called after throwing an instance of 'unsigned long'
Could you help on it?
Kris
I have the same environment and did exactly what is recommended in https://software.intel.com/en-us/node/671831 after installation of Intel OpenCL from https://software.intel.com/en-us/intel-opencl/download. But, when invoking Eclipse Mars.2 I have messages kind of "Cannot get machine/platform/device list. Failed to initialize code builder API." What may be the problem?
Hi Robert,
I have a similar problem to Vitali K. I am using Eclipse Neon and I also get messages of the type "Cannot get machine/platform/device list. Failed to initialize code builder API." The command line version of ioc64 seems to work.
Nik
Robert I. (Intel) wrote:
Looking for more info on eclipse. Hope to get back to you soon.
I am trying to install intel SDK for openCL on a virtual machine. when I am trying to install opencl runtime env then it is giving output as "CPU is not supported". I complied the matrix multiplication program. It is compiling with some warning and creating the executable file. But when I am running the executable then it is giving error as follows:
./GEMM: error while loading shared libraries: libOpenCL.so.1: cannot open shared object file: No such file or directory
UPDATE:
now I fixed the path problem I think. A new error is coming.
root@VM1:/home/sudiptavm/workvm/codeSamples/withOpenCL/matrix_mult/GEMM# ./GEMM
Platforms (1):
[0] Intel(R) OpenCL [Selected]
Devices (1):
[0] QEMU Virtual CPU version 2.2.0 [Selected]
[ ERROR ] Sample application specific error: OpenCL error CL_DEVICE_NOT_AVAILABLE happened in file ../common/oclobject.cpp at line 447.
How can I solve it?
note: I installed OpenCL in the host machine which has Intel(R) Xeon(R) CPU E31280 @ 3.50GHz
With regards,
Sudipta
What do you see with the system analyzer? https://software.intel.com/en-us/articles/mss-sys-analyzer-linux
You can also see more about how OpenCL initialization is handling this environment with the Platform/Device Capabilities Viewer Sample.
Hi ,
I am trying to install intel opencl sdk on CentOS 7.2 core , but while installing it is giving the error GPU not supported
I am using intel i5 core on x86 and os is here on Vertual mechine Cent Os 7.2 core ,
can anyone help me on this
thank u
while installing the intel opencl sdk on x86 intel i5 core and os in vertual machine is CentOS 7.2 core
I am getting this error ,
but I have installed that dkms packages and java 8 also installed and 3D graphics option in VM ware also done
but again instalation time it is giving the same error i.e GPU not supported
need help , can anyone help on this issue
Hi TimurS,
Can you share what CPU SKU the system is on? What kernel the system is on?
For linux setup... please see these two pages:
https://software.intel.com/en-us/articles/sdk-for-opencl-gsg
https://software.intel.com/en-us/articles/sdk-for-opencl-2017-gsg-linux-os
-MichaelC
Hi, I am a new OCL dev trying to get everything off the ground so I can start playing with it.
I am running on an Inspiron prebuilt laptop running window 10 home, and operate in an Ubuntu 16.04.4 terminal.
When compiling through the C++ wrapper I get a large error string as follows:
/tmp/ccTKf6fE.o: In function `cl::detail::ReferenceHandler<_cl_device_id*>::release(_cl_device_id*)': oCLtest.cpp:(.text._ZN2cl6detail16ReferenceHandlerIP13_cl_device_idE7releaseES3_[_ZN2cl6detail16ReferenceHandlerIP13_cl_device_idE7releaseES3_]+0x14): undefined reference to `clReleaseDevice' /tmp/ccTKf6fE.o: In function `cl::detail::ReferenceHandler<_cl_context*>::release(_cl_context*)': oCLtest.cpp:(.text._ZN2cl6detail16ReferenceHandlerIP11_cl_contextE7releaseES3_[_ZN2cl6detail16ReferenceHandlerIP11_cl_contextE7releaseES3_]+0x14): undefined reference to `clReleaseContext' /tmp/ccTKf6fE.o: In function `cl::detail::ReferenceHandler<_cl_command_queue*>::release(_cl_command_queue*)': oCLtest.cpp:(.text._ZN2cl6detail16ReferenceHandlerIP17_cl_command_queueE7releaseES3_[_ZN2cl6detail16ReferenceHandlerIP17_cl_command_queueE7releaseES3_]+0x14): undefined reference to `clReleaseCommandQueue' collect2: error: ld returned 1 exit status
after the program defaults to OpenCL2.0.
I've done some poking around and believe that I haven't installed the SDK properly, or at the very least haven't linked it correctly, though I'm not familiar enough with bash commands to make any sense of what I'm supposed to do through it. Thanks in advance.
Hi TraceV,
Can you share your linker command? If your ocltest.cpp source is appropriate for sharing... can you start a new thread on the forum and attach it?
Edits:
Thanks for the comment. This looks like the OpenCL library isn't being linked in properly.
On Linux OS the linker will need to see libOpenCL.so... On Windows OS the linker will need to see OpenCL.lib... both are available from the Intel SDK for OpenCL Applications 2017 and 2019 beta respectively.
Adding -lOpenCL -L<path to libOpenCL.so> may get you across the finish line.
Also... Look out for deprecated functions when using OpenCL 2.0 which may not link as expected without the usage of macros... Some functions only exist for OpenCL 2.0 while some exist in 1.2 but are sometimes exposed with #define CL_USE_DEPRECATED_OPENCL_1_2_APIS... Examples that users evaluate may not specify which OpenCL version they expect, so a developer needs to consider tweaking the code in accordance with their platforms.
/Edits
Thanks for your interest,
-MichaelC
For more complete information about compiler optimizations, see our Optimization Notice.
