OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
Why do small changes make in kernel code wrong results?
tooguni
The following kernel (my_kernel()) which is written based on my_function() calculates wrong results on Intel GPU.
The same code works well on Intel CPU and AMD GPU platform.
If you change the type of array index (idx) from unsigned long to unsigned int, the kernel calculates correct results, but I think that both should calculate correct results.
Which is caused this problem? By my code or Intel OpenCL SDK?
const char* kernel_str =
"__kernel \n"
"void my_kernel(__global const unsigned char* src, \n"
"               __global unsigned char*       dst, \n"
"               const unsigned long           elements) \n"
"{ \n"
"  const unsigned long gid = get_global_id(0); \n"
"  const unsigned long idx = 3 * gid; // NG\n"
"  //const unsigned int idx = 3 * gid; // OK\n"
"  if (! (gid < elements)) { \n"
"    return; \n"
"  } \n"
"  float r = ((float)src[idx] + (1.5f * (float)src[idx + 2])) - 18.0f;\n"
"  float g = (((float)src[idx] - (0.4f * (float)src[idx + 1])) - (0.7f * (float)src[idx + 2])) + 14.0f;\n"
"  float b = ((float)src[idx] + (1.8f * (float)src[idx + 1])) - 23.0f;\n"
"  r = clamp(r, 0.0f, 255.0f); \n"
"  g = clamp(g, 0.0f, 255.0f); \n"
"  b = clamp(b, 0.0f, 255.0f); \n"
"  dst[idx + 0] = convert_uchar(r); \n"
"  dst[idx + 1] = convert_uchar(g); \n"
"  dst[idx + 2] = convert_uchar(b); \n"
void my_function(const cl_uchar*     src,
                 cl_uchar*           dst,
  for (unsigned long gid = 0; gid < elements; ++gid) {
    r = std::min(std::max(0.0f, r), 255.0f); // clamp
    g = std::min(std::max(0.0f, g), 255.0f);
    b = std::min(std::max(0.0f, b), 255.0f);
    dst[idx + 0] = (cl_uchar)r;
    dst[idx + 1] = (cl_uchar)g;
    dst[idx + 2] = (cl_uchar)b;
I am using these environments.
OS : Windows 10 Pro 64bit
Device Name : Intel(R) Iris(TM) Pro Graphics 580
Device Driver Version : 21.20.16.4542
Intel OpenCL SDK : 2016 R3
Device Name : Intel(R) HD Graphics 530
Device Driver Version : 20.19.15.4501
Intel OpenCL SDK : 2016 R2
I attach a source code and VC project.
Jeffrey_M_Intel1
Thanks for your great reproducer!  We're processing this as a bug.
Jeffrey_M_Intel1
tooguni
Thanks for your reply.
