OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
Xeon Phi 64-bit Atomics
Simon_S_1
the Xeon Phi does only support the following extensions: cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_spir cl_khr_fp64
That means we are not able to use 64-bit atomic operations. Is there any possibility to use atomics for 64-bits? (cl_khr_int64_base_atomics)
That is absolutely necessary for many scientific applications, because float does not suffices in precision.
Regards, Simon Scholl
Yuri_K_Intel
Hi Simon, Sorry, but I can only confirm that 64-bit atomics are not supported by Xeon Phi. Thanks, Yuri
Yuri_K_Intel
