Community
cancel
Showing results for
Search instead for
Did you mean:
Javier_C_1
cannot start new session on Eclipse Neon
The first time I tried OpenCL on Eclipse it worked fine but the next time I opened the program the tool bar was grey (I could not select any target machine, platform or device) and I cannot start a new session because after setting a name and a location, pressing OK has no effect, the windows stays and nothing happens.
I installed the OpenCL SDK again and I copied the .jar to the right folder again but the error stays. What is wrong? I also made sure that the OpenCL bin directory was right.
Thanks in advance!
Javier_C_1
That is the point where I get stuck:
If I click on OK, nothing happens and the New Session window stays. That did not happen the first time I tried it so there must be something that changed even though I did not change any set up and I reinstalled the SDK several times with no better results.
