I'm implementing my design using channels over 1024.
typedef channel ap_uint<8> fifo_t;
fifo_t c0[2048] __attribute__((depth(4)));
The problem is that I cannot perform the emulation due to the following error.
aoc: Environment checks are completed successfully.
aoc: If necessary for the compile, your BAK files will be cached here: /var/tmp/aocl/
You are now compiling the full flow!!
aoc: Selected default target board de5a_net_ddr4
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Compiling for Emulation ....
Compiler Error: Emulator: Too many channels. Emulator can currently only handle 1024
Error: Optimizer FAILED.
Refer to xxx/xxx.log for details.
How can I pass the emulation or avoid this with large number of channels?
I tried to use std::queue for only emulation but aoc didn't recognize "#include<queue>".
Topic Options
