I am trying to build program which uses include files from another folder. I use -I key to specifiy path to that folder, but if I use quotes in file name it fails to build on GPU (it is ok on CPU). Without quotes I cannot use path with spaces. Is this a known restriction or a bug?
System: Win7 x64; GPU Driver: 9.18.10.3165
Log:
Platform: Intel(R) OpenCL
Device: Intel(R) HD Graphics 4000
Units: 16
Kernel file: kernel_median.cl
- Kernel build log ------------
-I "C:\_app_data\Intel\IPP\ipp\opencl\" -D BLK_X=128 -D BLK_Y=8
:11:10: fatal error: 'clpp.cl' file not found
#include "clpp.cl"
error: front end compiler failed build.
Error -11 in clBuildProgram: CL_BUILD_PROGRAM_FAILURE
Hi Pavel,
I was able to reproduce the issue. I will file a bug.
Raghu
