Community
cancel
Showing results for
Search instead for
Did you mean:
sai_rahul_c_
clBuildProgram taking long time to build the program
I am using clBuildProgram in VC 2008 and 2012 and both flows take long time to build the program. Till now, I am experienced with Linux OpenCL runtime, and since HD graphics support is only for Windows I started using it. Is this a common aspect with the Visual Studio flow ? If not any solutions for this problem.
Thank you,
Sai.
How big is your kernel? And what are you comparing against? Other vendor OCL compilers or the CPU compiler? Any chance you can attach your kernel?
