Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
clEnqueueNDRangeKernel may fail when using 2D local arrays
clEnqueueNDRangeKernel may fail on kernel with 2D local arrays but succeed with 1D local arrays and manual index computing.
For example, the following matrix multiplication kernel fails with CL_OUT_OF_RESOURCES if USE_2D is defined and succeedes otherwise.
Matricies are [24, 72] * [24, 72]T = [24, 24] and BLOCK_SIZE = 24.
#define BLOCK_SIZE 24
#define C_WIDTH 24
#define AB_COMMON 72
__kernel __attribute__((reqd_work_group_size(BLOCK_SIZE, BLOCK_SIZE, 1)))
void mx_mul(__global const float *A,
            __global const float *B,
            __global float *C) {
#ifdef USE_2D
  __local float AS[BLOCK_SIZE][BLOCK_SIZE];
  __local float BS[BLOCK_SIZE][BLOCK_SIZE];
#else
  __local float AS[BLOCK_SIZE * BLOCK_SIZE];
  __local float BS[BLOCK_SIZE * BLOCK_SIZE];
#endif
  int bx = get_group_id(0);
  int by = get_group_id(1);
  int tx = get_local_id(0);
  int ty = get_local_id(1);
  int a_offs = (by * BLOCK_SIZE + ty) * AB_COMMON + tx;
  int b_offs = (bx * BLOCK_SIZE + ty) * AB_COMMON + tx;
  float sum = 0;
  for (int i = 0; i < AB_COMMON / BLOCK_SIZE; i++, a_offs += BLOCK_SIZE, b_offs += BLOCK_SIZE) {
#ifdef USE_2D
    AS[ty][tx] = A[a_offs];
    BS[ty][tx] = B[b_offs];
#else
    AS[ty * BLOCK_SIZE + tx] = A[a_offs];
    BS[ty * BLOCK_SIZE + tx] = B[b_offs];
#endif
    barrier(CLK_LOCAL_MEM_FENCE);
    #pragma unroll
    for (int k = 0; k < BLOCK_SIZE; k++) {
#ifdef USE_2D
      sum += AS[ty] * BS[tx];
#else
      sum += AS[ty * BLOCK_SIZE + k] * BS[tx * BLOCK_SIZE + k];
#endif
  C[get_global_id(1) * C_WIDTH + get_global_id(0)] = sum;
Tested on Ubuntu 14.10 and Core i7-3770 with intel_sdk_for_ocl_applications_xe_2013_r3_sdk_3.2.1.16712_x64.
Highlighted
This issue seems to be resolved in intel_sdk_for_ocl_applications_2014_beta_sdk_4.0.1.17537_x64.
