OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
getting a crash when building a program
Moore__Christopher
Crashing on build
Kernel is attempting to average float8 values between neighboring elements of inputBuffer and then multiply them by associated 64 elements in matrixBuffer
Crash occurs when DIM is 2 or 3, both multiplies are performed, and both stateL and stateR are read from.
Setting DIM to 1 avoids the crash.
Reading only stateR avoids the crash.
#define DIM 3
__kernel void calcFlux(
	__global float8* resultBuffer,
	const __global float8* inputBuffer,
	const __global float8* matrixBuffer)
#if DIM == 1
	int4 i = (int4)(get_global_id(0), 0, 0, 0);
	if (i.x < 1 || i.x >= 64) return;
#elif DIM == 2
	int4 i = (int4)(get_global_id(0), get_global_id(1), 0, 0);
	if (i.x < 1 || i.x >= 64 || i.y < 1 || i.y >= 64) return;
#elif DIM == 3
	int4 i = (int4)(get_global_id(0), get_global_id(1), get_global_id(2), 0);
	if (i.x < 1 || i.x >= 64 || i.y < 1 || i.y >= 64 || i.z < 1 || i.z >= 64) return;
#else
#error unsupported DIM
#endif
	int index = i.x + 64 * (i.y + 64 * i.z);
	for (int side = 0; side < DIM; ++side) {
		int4 iPrev = i;
		--iPrev[side];
		int indexPrev = iPrev.x + 64 * (iPrev.y + 64 * iPrev.z);
		float8 stateL = inputBuffer[indexPrev];
		float8 stateR = inputBuffer[index];
		int interfaceIndex = side + DIM * index;
		float8 stateAvg = (stateR + stateL) * .5f;
#if 1	//crashes
		float8 result;
		for (int i = 0; i < 8; ++i) {
			float8 mrow = matrixBuffer[i + 8 * interfaceIndex];
			result = dot(mrow.s0123, stateAvg.s0123) + dot(mrow.s4567, stateAvg.s4567);
		resultBuffer[interfaceIndex] = result;
#endif
#if 0	//crashes
		float8 result = (float8)(0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f);
			for (int j = 0; j < 8; ++j) {
				result += mrow * stateAvg;
#endif
#if 0	//crashes
		float8 ma = matrixBuffer[0 + 8 * interfaceIndex];
		float8 mb = matrixBuffer[1 + 8 * interfaceIndex];
		float8 mc = matrixBuffer[2 + 8 * interfaceIndex];
		float8 md = matrixBuffer[3 + 8 * interfaceIndex];
		float8 me = matrixBuffer[4 + 8 * interfaceIndex];
		float8 mf = matrixBuffer[5 + 8 * interfaceIndex];
		float8 mg = matrixBuffer[6 + 8 * interfaceIndex];
		float8 mh = matrixBuffer[7 + 8 * interfaceIndex];
		float ra = dot(ma.s0123, stateAvg.s0123) + dot(ma.s4567, stateAvg.s4567);
		float rb = dot(mb.s0123, stateAvg.s0123) + dot(mb.s4567, stateAvg.s4567);
		float rc = dot(mc.s0123, stateAvg.s0123) + dot(mc.s4567, stateAvg.s4567);
		float rd = dot(md.s0123, stateAvg.s0123) + dot(md.s4567, stateAvg.s4567);
		float re = dot(me.s0123, stateAvg.s0123) + dot(me.s4567, stateAvg.s4567);
		float rf = dot(mf.s0123, stateAvg.s0123) + dot(mf.s4567, stateAvg.s4567);
		float rg = dot(mg.s0123, stateAvg.s0123) + dot(mg.s4567, stateAvg.s4567);
		float rh = dot(mh.s0123, stateAvg.s0123) + dot(mh.s4567, stateAvg.s4567);
		resultBuffer[interfaceIndex] = (float8)(ra, rb, rc, rd, re, rf, rg, rh);
#endif
stack trace:
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000000000c
VM Regions Near 0xc:
    __TEXT                 00000001071e6000-00000001071f4000 [   56K] r-x/rwx SM=COW  /Users/USER/*
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.apple.driver.AppleIntelHD4000GraphicsGLDriver    0x00001234003fbaa8 gldBuildComputeProgram + 84
1   com.apple.opencl                  0x00007fff91c302a4 0x7fff91c2c000 + 17060
2   com.apple.opencl                  0x00007fff91c3e574 clBuildProgram + 2072
3   test                              0x00000001071e9e0f cl::Program::build(std::__1::vector<cl::Device, std::__1::allocator<cl::Device> > const&, char const*, void (*)(_cl_program*, void*), void*) const + 255
4   test                              0x00000001071e90f1 main + 6033
5   libdyld.dylib                     0x00007fff91bb95fd start + 1
CL device properties:
CL_DEVICE_NAME:	HD Graphics 4000
CL_DEVICE_VENDOR:	Intel
CL_DEVICE_VERSION:	OpenCL 1.2
CL_DRIVER_VERSION:	1.2(May  5 2014 20:39:17)
CL_DEVICE_VENDOR_ID:	16925696
CL_DEVICE_PLATFORM:	0x7fff0000
CL_DEVICE_AVAILABLE:	1
CL_DEVICE_COMPILER_AVAILABLE:	1
CL_DEVICE_MAX_CLOCK_FREQUENCY:	1200
CL_DEVICE_MAX_COMPUTE_UNITS:	16
CL_DEVICE_TYPE:	4
CL_DEVICE_ADDRESS_BITS:
	CL_FP_SOFT_FLOAT
CL_DEVICE_HALF_FP_CONFIG:	-failed-
CL_DEVICE_SINGLE_FP_CONFIG:
	CL_FP_INF_NAN
	CL_FP_ROUND_TO_NEAREST
	CL_FP_ROUND_TO_ZERO
	CL_FP_ROUND_TO_INF
CL_DEVICE_ENDIAN_LITTLE:	1
CL_DEVICE_EXECUTION_CAPABILITIES:
	CL_EXEC_KERNEL
CL_DEVICE_ADDRESS_BITS:	64
CL_DEVICE_GLOBAL_MEM_SIZE:	1073741824
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE:	0
CL_DEVICE_GLOBAL_MEM_CACHE_TYPE:	0
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE:	0
CL_DEVICE_LOCAL_MEM_SIZE:	65536
CL_DEVICE_LOCAL_MEM_TYPE:	1
CL_DEVICE_MEM_BASE_ADDR_ALIGN:	1024
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE:	128
CL_DEVICE_IMAGE_SUPPORT:	1
CL_DEVICE_IMAGE2D_MAX_WIDTH:	16384
CL_DEVICE_IMAGE2D_MAX_HEIGHT:	16384
CL_DEVICE_IMAGE3D_MAX_WIDTH:	2048
CL_DEVICE_IMAGE3D_MAX_HEIGHT:	2048
CL_DEVICE_IMAGE3D_MAX_DEPTH:	2048
CL_DEVICE_MAX_CONSTANT_ARGS:	8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE:	-failed-
CL_DEVICE_MAX_MEM_ALLOC_SIZE:	268435456
CL_DEVICE_MAX_PARAMETER_SIZE:	1024
CL_DEVICE_MAX_READ_IMAGE_ARGS:	128
CL_DEVICE_MAX_WRITE_IMAGE_ARGS:	8
CL_DEVICE_MAX_SAMPLERS:	16
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR:	1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT:	1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT:	1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG:	1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT:	1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE:	0
CL_DEVICE_MAX_WORK_GROUP_SIZE:	512
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS:	3
CL_DEVICE_MAX_WORK_ITEM_SIZES:	(512, 512, 512)
CL_DEVICE_PROFILE:	FULL_PROFILE
CL_DEVICE_PROFILING_TIMER_RESOLUTION:	80
CL_DEVICE_QUEUE_PROPERTIES:	2
Moore__Christopher
The for-loop is the problem.
A #pragma unroll does not fix it -- the segfault still occurs upon building the program.
However manually unrolling the loop or keeping the loop and moving the loop body into a separate function does fix it.
