https://github.com/gammastorm/GammaOCL
here I try to code an own implementation of CopenCL for CPUs.
But even the debugging output is not printed.
Any ideas, why this is so ?
Thorsten Kiefer
Dear Thorsten,
If you have an issue with Intel OpenCL tools or drivers, please follow this check list when reporting it on the forum to ensure fast service:
- Please let us know what Processor, Operating System, Graphics Driver Version, and Tool Version you are using
- Please state steps to reproduce the issue as precisely as you possibly could
- If you are using command line tools, please provide the full command line
- If code is involved, it is great to create a small "Reproducer" sample and attach it to the message in the form of a zip file
- If you don't want your code to be seen by other forum users, please send me a private message
- Before posting, search the forum to see if someone already answered a similar question
Thank you!
1. Intel Core 2 Duo, Peppermint 6, OpenGL renderer string: Mesa DRI Mobile Intel® GM45 Express Chipset x86/MMX/SSE2
2. strace clinfo :
close(4) = 0
munmap(0xb7736000, 4096) = 0
open("/home/thorsten/NetBeansProjects/GammaOCL/GammaOCL/dist/Debug/GNU-Linux/libGammaOCL.so", O_RDONLY|O_CLOEXEC) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\2207\0\0004\0\0\0"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0775, st_size=124156, ...}) = 0
mmap2(NULL, 33900, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xb772e000
mmap2(0xb7735000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x6000) = 0xb7735000
close(4) = 0
4. https://github.com/gammastorm/GammaOCL/blob/master/GammaOCL/dispatch.cpp#L16
Output does not appear !!!
