OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1719 Discussions
"clBuildProgram" hangs on Intel HD Graphic 3000
Michaël_J_
The OpenCL function "clBuildProgram" hangs on those specific systems (while every thing works well on other ones):
Intel HD Graphic 3000 on Win 8.1 with this specific driver (9.17.10.3347) + possibly some Intel HD 4000
So, it seems to concern only a small list of chipsets, cf: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22672&keyword=9.17.10.3347&DownloadType=Drivers&lang=eng
Before compilling the program I am testing the device with the following:
[cpp]
// Check device availability & capability
  cl_bool isDeviceAvailable, isDeviceCompilerAvailale;
  if (!GetDeviceInfo(deviceIDs[deviceIndex], CL_DEVICE_AVAILABLE, isDeviceAvailable) || isDeviceAvailable != CL_TRUE ||
  !GetDeviceInfo(deviceIDs[deviceIndex], CL_DEVICE_COMPILER_AVAILABLE, isDeviceCompilerAvailale) || isDeviceCompilerAvailale != CL_TRUE)
    if (verbose) Log::Warning("%s::%d OpenCL device %d::%d not available.", __FUNCTION__, __LINE__, platformIndex, deviceIndex);
    continue;
  cl_device_exec_capabilities executionCapabilities;
  if (GetDeviceInfo(deviceIDs[deviceIndex], CL_DEVICE_EXECUTION_CAPABILITIES, executionCapabilities) || !(executionCapabilities & CL_EXEC_KERNEL))
    if (verbose) Log::Warning("%s::%d OpenCL device %d::%d has not the required execution capabilities.", __FUNCTION__, __LINE__, platformIndex, deviceIndex);
    continue;
[/cpp]
None of those functions tell me that the device have a lack of OpenCL support; although I am working on legacy code "Extensions" and "clImages" are neither used.
Unortunately, I don't have the above hardware and the problem only occurs on client desktops, so I was not able to reproduce it on my own hardwares and go further with tracking down the problem. However I got able to get the call stack hanging entry point which is the function "clBuildPrograms".
PS: I have seen exact same problem on an older thread, but after the bug submission no update was made:
http://software.intel.com/en-us/forums/topic/329291
PS: The driver is unique for those plateformes, so cannot advice customers to update/downdate it.
PS: I have also seen that there is "similar" OpenCL known issue with Intel HD Graphics laster driver:
http://downloadmirror.intel.com/23102/eng/releasenotes_gfx_3223_64.pdf
"When two applications are concurrently using OpenCL, the graphics driver may crash."
Thank you very much.
Kind Regards,
Michaël Jeulin-L.
