Processors
14530 Discussions
İ5-4210u işlemcim 0.77GHZ takıldı kaldı hiçbir tepki vermiyor yardımcı olurmusunuz?
oberb1
Wanner_G_Intel
Hello oberb1, Thank you for posting on this Community. BIOS and Windows* Power Management settings may cause this behavior. We recommend following these steps: 1. Check Windows* Power options. For example, you can change the Power Plan and the Minimum/Maximum processor state. Make sure your power options are set to High Performance for better results. 2. We also recommend loading default BIOS settings to make sure voltage and other parameters are correct. 3. Is your operating system up to date? Try checking Windows* updates, scan and apply all of them. Note: We only provide support in English. For this reason, we are using a translation tool to better assist you. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello oberb1, Were you able to review the information provided? Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello oberb1, Please contact us if you have any additional questions. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
