Merhaba MSI B250M Bazooka anakartım var ve kuruluyoruz İ7 6700 işlemciye OC yapmak istiyorum. Nasıl OC yapılır?
Hello Onur Aydın,
I understand that you are looking to overclock your processor.
This is something not possible from our side, starting with the processor not being unlocked, our processors that are unlocked end with a "K" or "X" and they are overclockable. Also, the overclocking process is not recommended by Intel ® because it pushes the processor further over the limit and that could reduce the life time of the processor or even increase the temperature at which it operates.
So, in other words, from intel's side there is no way to overclock the processor if it is locked, I am uncertain if there is any application or third party software that allows you to do so, remember however, that manipulating the voltage or increasing frequency can potentially damage the processor and may even void the warranty of it.
I hope this helps.
David V
Hello ONuR57,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
