Processors
13883 Discussions
Поддерживает ли процессор данную оперативную память
patkerson
Поддерживает ли процессор intel core 2 quad q8200 максимальный объем оперативной памяти 8GB с частотой 1333
Оперативная память AMD Radeon R3 Value Series [R334G1339U1S-U] 4 ГБ [DDR3, 4 ГБx1 шт, 1333 МГц, PC10600, 9-9-9-24]
n_scott_pearson
Super User Retired Employee
Technically speaking, because the memory controllers are in the chipset (MCH or GMCH component) and not in the processor, the processor has no memory type, size or speed to speak of. You need to be asking based upon what motherboard you have, what chipset it supports and the type of memory (i.e., whether DDR2 or DDR3) that it supports. Typically,
  • If you have a 3 Series Chipset, you are limited to 8GB of DDR2 memory.
  • If you have a 4 Series Chipset, you are limited to either 8GB of DDR2 memory or 8/16GB of DDR3 memory.
The motherboard's BIOS (memory initialization code) plays a significant role in determining the memory speeds and densities supported. Bottom line, you need to look at the documentation for your motherboard in order to answer this question.
Hope this helps,
David_G_Intel
Hello patkerson
Thank you for posting on the Intel️® communities.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped. You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued". https://ark.intel.com/
Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
David G
Intel Customer Support Technician
