Community
cancel
Showing results for
Search instead for
Did you mean:
ДБерг
Помогите разобраться.
Не так давно начал очень сильно проседать ФПС в играх(со 120 до 10-20)даже на минимальных настройках.
Aces Aspire V5-571G
Intel(R)Core i5-3317U CPU 1.70 GHz
Win 7 64-bit
GPU 0 intel HD Graphics 4000
GPU 1 Nvidia Geforce GT 620-M
6 Gb RAM
Диагностика через Intel Processor Diagnostic Tool не проходит.
Подскажите пожалуйста в чем может быть дело?
--- IPDT64 - Revision: 4.1.0.24
--- IPDT64 - Start Time: 07.02.2018 17:52:38
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Fail.
IPDT64 Failed
--- IPDT64 - End Time: 07.02.2018 17:57:28
FAIL
--- Genuine Intel Test ---
Version 1.0.14.64b.W
Expected -- GenuineIntel
Detected -- GenuineIntel
Genuine Intel CPU Module Success
--- Brand String Test ---
Version 1.0.17.64b.W
IntelR CoreTM i5-3317U CPU 1.70GHz
Brand String Module Success....
--- Cache Test ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size -- 32
- Detected L1 Inst Cache Size -- 32
- Detected L2 Cache Size -- 256
- Detected L3 Cache Size -- 3072
Cache Module Success
--- MMXSSE Test ---
Version 1.0.19.64b.W
..DetectUtils64 DLL Version - 1.1.2
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
Testing MMX
Dot Product computed using C code 506
Dot Product computed using MMX intrinsics 506
MMX Dot Product Computation Test Passed
Passed MMX Test
Testing SSE
Dot Product computed using SSE intrinsics 506
SSE Dot Product Computation Test Passed
Passed SSE Test
Testing SSE2
Complex Product computed using C code 23.00 -2.00i
Complex Product computed using SSE2 code 23.00 -2.00i
SSE2 Complex Product Computation Test Passed
Passed SSE2 Test
Testing SSE3
Complex Product using C code 23.00 -2.00i
Complex Product using SSE3 code 23.00 -2.00i
SSE3 Complex Product Computation Test Passed
Passed SSE3 Test
Testing SSSE3
SSSE3 Absolute Value Tests Passed
SSSE3 Arithmetic Tests Passed
SSSE3 Dot Product Test Passed
Passed SSSE3 Test
Testing SSE4.1
SSE4.1 Blend Tests Passed
SSE4.1 Min Max Tests Passed
SSE4.1 Insert Bit Tests Passed
SSE4.1 Extract Bit Tests Passed
SSE4.1 Bitwise Comparison Tests Passed
SSE4.1 Dot Product Test Passed
SSE4.1 Arithmetic Tests Passed
SSE4.1 Bit Conversion Tests Passed
SSE4.1 Bit Compare Test Passed
Passed SSE4.1 Test
Testing SSE4.2
SSE4.2 Bit Compare Test Passed
SSE4.2 Calculate Bit Set to 1 Test Passed
SSE4.2 CRC Test Passed
Passed SSE4.2 Test
MMXSSE Module Success
--- Integrated Memory Controller Test ---
Version 1.0.10.64b.W
StatusFMmatched 0
--- Reading Memory Size ---
Detected Memory Size is -- 6.00GB
--- Subtest - Memory Size Test Passed ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed ---
--- Integrated Memory Controller Stress Test Passed ---
Parallel_PrimeNum_i5
Version - 1.0.0.8
Parsing Parallel_PrimeNum_i5.xml
Running Module Math_PrimeNum.exe -s 20 -resultName Math_PrimeNum_Parallel_PrimeNum_i5_1_Results.txt
Running Module VisParticle.exe -ps 1.0 -ws 700 -s 20 -resultName VisParticle_Parallel_PrimeNum_i5_1_Results.txt
Running Module VisCollisions.exe -step 5 -ws 550 -s 20 -resultName VisCollisions_Parallel_PrimeNum_i5_1_Results.txt
--- Prime Number Generation Test ---
AVX is supported in your OS
Max AVX supported AVX
Ops Per Sec CycleRun Error Timesec
9695.25 1 0 4
12478.33 2 0 7
9922.25 3 0 11
12867.33 4 0 14
9600.25 5 0 18
52416 7 0 19
54435 9 ...
Community Manager
Hello Darya76,
Thank you for contacting Intel® Communities Support.
I am sorry to hear that your processor is not working properly, I understand that you run the Intel® Processor Diagnostic Tool and the test has failed.
At this point I suggest you to contact your laptop manufacturer since you have a laptop processor they are the one who can help you with the replacement process.
Also as 1 last recommendation I suggest you to contact the video card manufacturer:
http://www.nvidia.com/object/support.html
They can provide you drivers and the best configuration for gaming.
Let us know if you need further assistance.
Stephen C.
