Решил я опгрейдить мой ноутбук asus n73sv, стоял процессор i5 2430m поставил я i7 2670qm, все завилось и работает нормально...Но частота не 2.2 гц, а 2.0 гц под нагрузкой, с температурой все впорядке, максимальная температура 70 градусов. Помогите, как решить эту проблему
Andrey.Bodur: Thank you very much for joining the Intel® Processors communities. We are sorry to hear the laptop is not working as expected.
In regard to your inquiry, remember that when you are going to do an upgrade on a laptop we always recommend to verify with the manufacturer of it if the processor that you are going to install will be fully compatible, not only in reference to socket but also at BIOS level and at software level, since some features from the laptop might not work properly with a different processor. In this case the best thing to do to try to fix this problem will be to get in contact directly with ASUS, to check if they have further suggestions or troubleshoot steps for this scenario and also in the case a warranty procedure is needed for your device:
https://www.asus.com/ru/ https://www.asus.com/ru/
Any further questions, please let me know.
Alberto R
