Community
cancel
Showing results for
Search instead for
Did you mean:
АДмит1
Проблема с процессором
При включении компа сразу после сборки не включается монитор. Судя по спикеру, проблема в процессоре. Можно ли как-то почистить контакты или сделать что-либо ещё перед тем, как нести его обратно в магазин?
Community Manager
Hello Lobzyak,
As per the translate option, you are facing a no boot problem with your system. We can certainly work on that to find a possible solution for the problem!
I would like to thank you for joining our communities support forum as well!
First, I would like to get some data from the system to check compatibility and have a better understanding of the scenario faced.
Please provide the following:
-OS (Operating System):
-CPU (Processor full model number):
-Motherboard model number:
-RAM:
-Drives connected
Also, have you followed the recommendations here? http://intel.ly/2w9uapD http://intel.ly/2w9uapD
Please let me know how it goes.
PD: This support is provided in English only, sorry for any inconvenience.
Esteban C
Community Manager
Hello Lobzyak,
This message is to follow up on your case, and find out if you were able to check my previous post.
Esteban C
