Processors
14674 Discussions
Совместимость i3-9100F и Asrock H310CM-HDV
ANike
Друзья, установил Процессор Intel Original Core i3 9100F Soc-1151v2 (CM8068403377321S RF7W) (3.6GHz) OEM в Asrock H310CM-HDV, пищит 5 раз. На сайте производителя мат. платы, совместимы. https://www.asrock.com/MB/Intel/H310CM-HDV/index.ru.asp#CPU В чем может быть проблема? Память DDR4 4Gb 2400MHz Crucial CT4G4DFS824A RTL PC4-19200 CL17 DIMM 288-pin 1.2В kit single rank х2шт. Видюху не устанавливал.
Wanner_G_Intel
Hello ANike,
Thank you for submitting your question on this Intel® Community.
First, we would like to know if the problem you are describing is that your computer has "No Post issues".
Based on the CPU Support List, your Intel® Core™ i3-9100F Processor should be compatible with Asrock H310CM-HDV motherboard.
Note: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Now, to better assist you, we would like to have more information about your system configuration:
  • Do you know the BIOS version installed on the motherboard?
  • Besides the POST or Beep codes you are receiving, does your motherboard support onboard LEDs?
  1. These LEDs can also let us know if the cause of the problem is the processor, a VGA error, etc.
  • What components are you trying to boot the computer with?
Note: Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
A Contingent Worker at Intel
Wanner_G_Intel
Hello ANike,
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
ANike
Hello, Im add videocard and all work.
Wanner_G_Intel
Hello ANike,
Thank you for the update.
We will close this inquiry. If you need further assistance, please post a new question. We will be glad to assist you.
Wanner G.
