Processors
14536 Discussions
无法使用XTU解锁功耗墙
bsagyh
只要我提升Turbo boost power max选项,过几秒种就会自动地重新降低,这样根本无法解锁功耗墙的限制,玩游戏降频掉帧很难受。
CPU型号为i7-11800H
AndrewG_Intel
Hello @bsagyh
请注意,我只能用英语支持您。我使用了一个网络翻译工具来翻译这个回复,因此,可能会有一些不准确的翻译。
We understand that you have some issues with the Turbo Boost Power Max option in the Advanced Tuning tab of Intel® Extreme Tuning Utility (Intel® XTU).
We would like to inform you that Intel XTU may or may not work on unsupported processors and the Intel® Core™ i7-11800H Processor is not in the "valid product list". This is noted in the download webpage for Intel® XTU.
Some versions of Intel® Extreme Tuning Utility can be installed in laptops or systems and these versions will not work for overclocking purposes. This is because overclocking with Intel® Extreme Tuning Utility only works for Intel® Core™ processors that include the letter K or X in the product line suffix.
When the tool is installed on your laptop with an unsupported processor, you can view system information parameters such as processor information and motherboard and BIOS information. However, using the tool to change parameters in your laptop, such as core voltage, can result in inconclusive and unreliable behavior due to unsupported processor.
For assistance to modify CPU parameters (whenever that is possible), we recommend using the tools provided by the computer manufacturer (OEM). Please contact your OEM for additional information, instructions, and recommendations.
Andrew G.
bsagyh
Great thanks for your answer.Now I know the problem exists.
AndrewG_Intel
Hello bsagyh
Sure! You are very welcome and thank you for your response.
Since there are no more questions in the thread, we will proceed to close it now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
It has been a pleasure to assist you.
Andrew G.
