Processors
14538 Discussions
求助!!Intel i7 eight processor thread four thread does not get rid of the blue screen, somehow?
I bought the bulk of CPU i7, the first day is not good, suspected motherboard problem, for a long time. The results of CPU itself have problems
@i7处理器4790k 原来的八线程偶尔蓝屏,之后变成严重蓝皮,找了很久问题,结果八线程改掉六线程不蓝屏了。 改六
@i7处理器4790k 原来的八线程偶尔蓝屏,之后变成严重蓝皮,找了很久问题,结果八线程改掉四线程不蓝屏了。
I7 processor 4790k the original eight threads occasionally into serious blue, blue screen, looking for a long time, the eight thread four thread does not get rid of the blue screen.
处理器散装买的!@
Please elaborate this issue because using google translator was not clear enough to understand how you tried to solve it.
I would like to have additional information about your system configuration. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
坏了 一个核心,二线程出现过蓝屏, 后来关掉了 坏了 一个核心,二线程出现过蓝屏, 后来关掉了
Bad core, two threads appear blue screen, and later in the BOSS closed
What type of memory or memory part number?
Please provide the system report and information about what troubleshooting steps have you tried to correct this situation?
Allan.
内存和主板不存在问题, 原来的八线程 出现报错总是这个 Memory, and motherboard there is no problem, the original eight threads There always this error。 Occasionally turn blue
Have to stop working,,,其他都有,不一定
Use the CPU test software, has already passed May not be compatible,
If not again, old practical three core, warranty has already expired too late to change new, really regret.
I have sent you a private message. Please check your Inbox.
Allan.
Buy from taobao CPU pieces and give one year warranty, the expired?? Because there is no box
你能修理吗?或改变新的吗?
Can you repair? Or change new?
Yes, Intel can help replacing the processor if you are still under warranty.
You can request warranty service by contacting your local support at http://www.intel.com/content/www/us/en/support/contact-support.html Intel® Processors
Or, you can check your private messages and reply the same way.
Hope this information is helpful.
Please do let me know if you need further assistance with your Intel product, I will be glad to assist you.
Allan.
