im trying to reduce the temperature of my processor because it often gets into thermal throttling while im gaming.
I already set a Core voltage offset to -0.050 V
Turbo boost power max 125 W with 28 s time window and short power max to 175 W.
System:
- i9 10900k
- ASRock Z490 Extreme
- GSkill Trident Z DDR4 3600 DIMM 2x 8 GB
- MSI MAG Core Liquid 360 R 360mm
- 6x Pure Wings 120x120x25 mm fans with 1500 U/ min
- be quiet Pure Base 500 DX Midi Tower
- M.2 970 Evo Plus
- 750Watt be quiet 80+ Plat
- ( GTX 970 )
test with cinebench R20
Thanks for any help
Hello Bentz,
In order to better assist you, please provide the following information:
- Is there any sign of physical damage on the processor?
- Was the processor overclocked? Please note that if the system was overclocked, including XMP beyond the processor supported specifications (DDR4-2933), your processor voids warranty.
- Was the processor running fine before? If so, when did the issue start?
- Have you checked if there is any pump failure, visible leaks or fluid loss?
- Is the BIOS up-to-date?
Steven G.
Hello Steven,
- No sign of physical damage, i just renewed the thermal paste, from outside it looked fine
- I didnt overclock it, when i was thinking about over clocking and start downloading programms like HWinfo, i figured out that i have a thermal problem
- When i bought this computer, the company who build it for me, forgot to remove the foil of the cpu cooler, after i removed it, i still had the issue with getting to hot, so i disabled the Turbo boost Technology, and there still points where it gets to the 100 C
- I have no tool to check it if my pump is running correctly, visually it looks good and one site is always hot and the other cold seems ok
- I just did a BIOS update, results:
it gets hoter now
the thermal past is also new.
Bentz
Thank you for your response.
In order to work on this further, please run a test using our Intel® Processor Diagnostic Tool https://www.intel.com/content/www/us/en/download/15951/19792/intel-processor-diagnostic-tool.html?
Let me know of the outcome of the test.
Steven G.
Hello Steve,
test results:
--- IPDT64 - Revision: 4.1.7.39
--- IPDT64 - Start Time: 01.09.2022 20:54:31
CPU1
Genuine Intel CPU Test
Module Version: 1.0.23.64b.W
Start Time: Thu Sep 1 20:54:31 2022
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Thu Sep 1 20:54:31 2022
Total Time: in seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.25.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM)
Detected: Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Cache Test
Module Version: 1.0.21.64b.W
Start Time: Thu Sep 1 20:54:32 2022
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 20480
Cache Size Test Passed!!!
End Time: Thu Sep 1 20:54:32 2022
CPU1
MMXSSE Test
Module Version: 1.0.27.64b.W
Test Result - PASS
DetectUtils64 DLL Version - 1.1.6
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 bytes
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Test Passed!!!
CPU1
Parallel_PrimeNum Test
Module Version: 1.0.0.11
Start Time: 01.09.2022 20:54:32
Test Result - PASS
Module Math_PrimeNum.exe Completed - Pass
Prime Number Generation Test
Module Version: 1.0.26.64b.W
AVX is supported in your OS
Max AVX supported = AVX2
Test Result - PASS
Operation Per Second: 109896
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Thu Sep 1 20:55:17 2022
Total Time: in seconds: 45
Parallel_PrimeNum
End Time: 01.09.2022 20:55:17
CPU1
Parallel_FP Test
Start Time: 01.09.2022 20:55:17
Test Result - PASS
Module AVX.exe Completed - Pass
Module Math_FP.exe Completed - Pass
AVX Test
Module Version: 2.0.28.64b.W
Start Time: Thu Sep 1 20:55:17 2022
Test Result - PASS
--- CPU Features Detection ---
..AVX is supported by this CPU..
..AVX2 is supported by this CPU..
..AVX512BW is NOT supported by this CPU..
..AVX512CD is NOT supported by this CPU..
..AVX512DQ is NOT supported by this CPU..
..AVX512ER is NOT supported by this CPU..
..AVX512F is NOT supported by this CPU..
..AVX512IFMA52 is NOT supported by this CPU..
..AVX512PF is NOT supported by this CPU..
..AVX512VBMI is NOT supported by this CPU..
..AVX512VL is NOT supported by this CPU..
..AES is supported by this CPU..
..PCLMULQDQ is supported by this CPU..
..AVX is supported by this Operating System..
Most Advanced AVX Feature Detected.. AVX2
AVX2 Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
End Time: Thu Sep 1 20:56:03 2022
Total Time: in seconds: 46
Floating Point Test
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.585
Error: 0
--- Floating Point Test Passed!!!---
End Time: Thu Sep 1 20:56:02 2022
Parallel_FP
End Time: 01.09.2022 20:56:04
CPU1
Parallel_Math Test
Start Time: 01.09.2022 20:56:04
Test Result - PASS
Module FMA3.exe Completed - Pass
Start Time: Thu Sep 1 20:56:04 2022
Test Result - PASS
Operation Per Second: 109731
Error: 0
End Time: Thu Sep 1 20:56:49 2022
FMA3 Test
Test Result - PASS
..FMA3 is supported by this CPU..
..FMA3 is supported by this Operating System..
FMA3 Test Result --- PASS
Parallel_Math
End Time: 01.09.2022 20:56:49
CPU1
Parallel_GPUStressW Test
Start Time: 01.09.2022 20:56:49
Test Result - PASS
Start Time: Thu Sep 1 20:56:49 2022
Test Result - PASS
Operation Per Second: 103959
Error: 0
End Time: Thu Sep 1 20:57:19 2022
Total Time: in seconds: 30
Floating Point Test
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.715
Error: 0
Parallel_GPUStressW
End Time: 01.09.2022 20:57:19
CPU1
DGEMM Stress Test
Module Version: 1.0.14.64b.W
Start Time: Thu Sep 1 20:57:19 2022
Test Result - PASS
DGEMM AVX2 Test Result --- PASS
End Time: Thu Sep 1 20:58:19 2022
Total Time: in seconds: 60
CPU1
Frequency Check
Module Version: 1.0.5.64b.W
Start Time: Thu Sep 1 20:58:19 2022
Test Result - PASS
Processor Name: Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz
Expected Processor Frequency: 3.70
Measured Processor Frequency: 3.694854
End Time: Thu Sep 1 20:58:20 2022
Total Time: in seconds: 1
System Information
Processor Information: Family 6 Model A5 Stepping 5
Number of Physical Cores: 10
Number of Logical Cores: 20
Operating System: Microsoft Windows 10 Pro 64-Bit
Graphics Information: NVIDIA GeForce GTX 970
--- IPDT64 - End Time: 01.09.2022 20:58:20
--- IPDT64 - Result: Pass
CPU1
Test Result - PASS
CPU1
Test Result - PASS
CPU1
Cache Test
Test Result - PASS
CPU1
MMXSSE Test
Test Result - PASS
CPU1
IMC Test
Test Result - PASS
Memory Allocated.
Memory Deallocated.
CPU1
Test Result - PASS
Test Result - PASS
Error: 0
Parallel_PrimeNum
CPU1
Parallel_FP Test
Test Result - PASS
AVX Test
Test Result - PASS
Floating Point Test
FMA3 supported
Test Result - PASS
Error: 0
Parallel_FP
CPU1
Parallel_Math Test
Test Result - PASS
Test Result - PASS
Error: 0
FMA3 Test
Test Result - PASS
Parallel_Math
CPU1
Test Result - PASS
Test Result - PASS
Error: 0
Floating Point Test
FMA3 supported
Test Result - PASS
Error: 0
Parallel_GPUStressW
CPU1
DGEMM Stress Test
Test Result - PASS
CPU1
Frequency Check
Test Result - PASS
System Information
Bentz
Thank you for the information.
I am going to work on this. As soon as I have an update, I will let you know.
Steven G.
Hello Bentz,
In order to further work on this issue, please provide the following information:
- Download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
- Is there any dust inside the case or anything blocking the airflow?
- Do temperatures go down and thermal throttling changes to "No" in XTU when not gaming?
- With which games are you experiencing the thermal throttling? Does it happen no matter the game you run?
Steven G.
Hello Steve,
i talked to the company where i bought my computer, they said there is a known issues with my cooler.
I removed it and send it back to them. When i get it back i let you know if that was the problem.
Best regards
Bentz
Please let us know as soon as you have an update on the matter.
Steven G.
Hello Steve,
it was the cooler, System running perfectly now.
Thanks for the help.
Bentz
I am glad to know you are now getting the right temperatures and the processor is working fine. Thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
Steven G.
