Hello everyone,
I recently purchased a 12700k along with an ASUS TUF Gaming Z690 Plus D4 motherboard. BIOS has been updated to the latest version 2204, Windows was freshly installed on a formatted SSD, and then standard chipset, audio, LAN drivers were installed from the ASUS website. I also have a TUF Gaming 6800XT and latest AMD drivers were installed for the GPU. All BIOS settings are set to default except ASUS MCE is off (Disabled, Enforce Power Limits). I also have a Corsair H100 Elite AIO cooler. My RAM kit is Corsair Vengeance 2x8gb 16-18-18-36 3200MHz, but running with XMP off for testing. PSU is an EVGA 1000w Gold.
I tested the system with OCCT and Cinebench R23 and had no issues at all! CPU temps were around 65-72 degrees during these tests. When gaming, CPU temps were similar and GPU temps were often in the mid 70s at highest utilization. I end up black screening, with a complete audio buzzing sound, and the system fans, GPU, etc keep running but cannot do anything on the PC. It needs to be shut down via the power button.
I am at a loss here especially because I am at stock bios settings with XMP off. Does anyone have any suggestions?
Event log reveals WHEA-Logger EVENT ID 1, and then a crash dump analysis reveals the following:
8: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* WHEA_UNCORRECTABLE_ERROR (124) A fatal hardware error has occurred. Parameter 1 identifies the type of error source that reported the error. Parameter 2 holds the address of the nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details. Arguments: Arg1: 0000000000000007, BOOT Error Arg2: ffffe188f64ee150, Address of the nt!_WHEA_ERROR_RECORD structure. Arg3: 0000000000000000 Arg4: 0000000000000000 Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 3374 Key : Analysis.DebugAnalysisManager Value: Create Key : Analysis.Elapsed.mSec Value: 6468 Key : Analysis.IO.Other.Mb Value: 7 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 19 Key : Analysis.Init.CPU.mSec Value: 968 Key : Analysis.Init.Elapsed.mSec Value: 11487 Key : Analysis.Memory.CommitPeak.Mb Value: 82 Key : Bugcheck.Code.DumpHeader Value: 0x124 Key : Bugcheck.Code.Register Value: 0x50c47120 Key : Dump.Attributes.AsUlong Value: 18 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 FILE_IN_CAB: WHEA-20221212-2103.dmp DUMP_FILE_ATTRIBUTES: 0x18 Kernel Generated Triage Dump Live Generated Dump BUGCHECK_CODE: 124 BUGCHECK_P1: 7 BUGCHECK_P2: ffffe188f64ee150 BUGCHECK_P3: 0 BUGCHECK_P4: 0 PROCESS_NAME: smss.exe STACK_TEXT: fffff182`50c470d0 fffff801`5975e35f : ffffe188`f64ee130 00000000`00000000 ffffe188`f64ee150 00000000`00000022 : nt!LkmdTelCreateReport+0x139 fffff182`50c47610 fffff801`5975e256 : ffffe188`f64ee130 fffff801`00000000 000000dc`00000000 000000dc`1497f480 : nt!WheapReportLiveDump+0x7b fffff182`50c47650 fffff801`595cacb1 : 00000000`00000001 fffff182`50c47ac0 000000dc`1497f480 00000000`00000280 : nt!WheapReportDeferredLiveDumps+0x7a fffff182`50c47680 fffff801`59452827 : 00000000`00000000 ffffe188`f6078ce0 00000000`00000103 00000000`00000000 : nt!WheaCrashDumpInitializationComplete+0x59 fffff182`50c476b0 fffff801`5920caf5 : ffffe188`f6500000 ffffe188`f6a75d30 fffff182`50c47ac0 ffffe188`00000000 : nt!NtSetSystemInformation+0x1f7 fffff182`50c47a40 00007ffa`799b05f4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 000000dc`1497f428 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`799b05f4 MODULE_NAME: GenuineIntel IMAGE_NAME: GenuineIntel.sys STACK_COMMAND: .cxr; .ecxr ; kb FAILURE_BUCKET_ID: LKD_0x124_7_GenuineIntel__UNKNOWN_IMAGE_GenuineIntel.sys OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {5ea80f6a-69bf-5d6f-8fd2-cd87deb91a03} Followup: MachineOwner ---------
8: kd> !errrec ffffe188f64ee150
Common Platform Error Record @ ffffe188f64ee150
Record Id : 01d90e9706503f2d
Severity : Fatal (1)
Length : 3552
Creator : Microsoft
Notify Type : BOOT Error Record
Timestamp : 12/13/2022 2:03:00 (UTC)
Flags : 0x00000002 PreviousError
Section 0 : Firmware Error Record Reference
Descriptor @ ffffe188f64ee1d0
Section @ ffffe188f64ee2a8
Offset : 344
Length : 2592
Flags : 0x00000000
Severity : Fatal
Section 1 : Firmware Error Record Reference
Descriptor @ ffffe188f64ee218
Section @ ffffe188f64eecc8
Offset : 2936
Length : 544
Flags : 0x00000000
Severity : Fatal
Section 2 : Firmware Error Record Reference
Descriptor @ ffffe188f64ee260
Section @ ffffe188f64eeee8
Offset : 3480
Length : 72
Flags : 0x00000000
Severity : Fatal
Hello, @Refrax21.
I am sorry to hear what is happening to your processor, I will gladly assist you to figure out a solution here.
Please, answer these questions to have a better perspective on this issue and try the following steps:
- Did you try setting the BIOS defaults in your motherboard?
- Remove any hardware or drivers recently installed that might be causing this BSOD.
- Try the Windows Safe mode. Check if there are any driver errors in the device manager and update device driver for the devices that are showing errors.
- Make sure you have the latest Windows updates. Go to Settings → Update & security → Windows Update, and then select Check for updates. When done, reboot your system.
- Try the minimal configuration (no Discrete Graphics card, motherboard, 1 RAM stick, SSD, power supply, less hardware components on your system).
- Test your RAM with the Windows Memory Diagnostic to check for memory issues.
- Did you check the power supply is working correctly?
- If possible, try other hardware in your system to discard any hardware issue (a known working SSD, processor, motherboard, RAM, etc.).
- Test the processor and attach the reports and screenshots, check on the notes:
Intel® Processor Diagnostic Tool
Note: As soon as you run it, it will start testing, please attach the complete Screenshot or click on "File", select the "View Results File" option, save and attach the report.
Intel® Extreme Tuning Utility (Intel® XTU)
Note: Click on "Stress Test" tab and "Start Testing" and then, attach a complete screenshot.
Jocelyn M.
Hello, @Refrax21.
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back.
Jocelyn M.
Hello, @Refrax21.
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
