Hello, @FatihO
Thank you for your time and patience.
The IccMax is essentially how much current is the CPU allowed to pull when working at 100% capacity, this value can vary depending on other Hardware configurations, not all CPUs will reach 100% at the same point depending on Motherboard, Memory, Cooler system, etc. For that reason, the datasheet is showing max values based on standard CPU SKUs.
Many Motherboard manufacturers set their configuration to default for stable usage and even some include a power limit that can be different from CPU.
For this specific case, we recommend you to keep it on default, if you are trying to change it, contact your System Manufacturer for further assistance.
In any case, make sure the system has a sufficiently powerful cooling solution before adjusting this, as it can have a substantial impact on the heat your CPU generates.
Jocelyn M.
Go to MSI for support of your motherboard and THEIR bios.
I looked for a bit in msi website but couldnt find anything.
Hello, @FatihO
Thank you for posting on the Intel® communities. I will do my best to assist you here.
I will do some research on this. As soon as I have updates, I will post them here.
Jocelyn M.
Hello Jocelyn,
I am waiting for your answer.
Thank you.
Hello, @FatihO
Jocelyn M.
I switched my motherboard with asus rog b760 a and all of my cpu bottleneck problems are gone.
I switched my motherboard with asus rog b760 a and all of my cpu bottlenck problems are gone. Iccmax value was set 500A for default but ı changed to 230A so my cpu is working cooler.
Hello, @FatihO
Thank you for your reply, I am glad to hear that you were able to cool your processor.
Since you have no more bottleneck problems, this thread will no longer be monitored, but if you need further assistance, feel free to contact us back and submit a new post.
Have a nice day.
Jocelyn M.
