The temps are around 50 degrees Celsius, and i saw this behaviour only ob demanding Games.
The GPU (4080) is running as it should.
I should mention that i also undervolted my CPU, could this be the Problem? Pls help me and pls tell ne what to do.
Thank u in advance
AlexLowas, Thank you for posting in the Intel® Communities Support.
In reference to your question about overclocking/underclocking it is important to mention that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. So yes, that fact could be the source of the problem.
In order to rule out a possible hardware issue with the processor, please install and run the Intel® Processor Diagnostic Tool, it does an overall test on the unit and if it passes the test it means it is working properly:
We also recommend to get in contact directly with ASRock Support in order to reset the BIOS to default settings and also to make sure the latest BIOS version is currently up to date or to gather the instructions on how to update it:
https://www.asrock.com/support/
Is there any graphics problem with the games?
Is there any graphics issue with the normal usage of the computer?
If the problem persists after trying the suggestions above, please attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
Albert R.
Hello AlexLowas, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Hello AlexLowas, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
